Hi everyone. I have a 2001 S-type SE 3L petrol.
The passenger side raise/lower temperature rocker switch on the climate control module; the illumination of the lower temperature (blue arrow) has stopped illuminating (raise red arrow illumination is ok), however the switch operation is still working ok, and all other switches on the consoles are illuminating and working.
Can anyone tell me if there is a bulb (or perhaps an LED) that needs replacing? - or do I need to order a new switch?
I have instructions for removing the complete centre "swoopy type" console (for fitting a Sat Nav unit), but don't want to risk damaging a perfect console facia etc just to have a look. I'd like to do the operation only once etc., so would appreciate any information anyone can give me.
Also regarding switch illumination; are the 3 passenger door window switches supposed to illuminate (i.e. their up/down arrows)? Again mine all work ok but don't illuminate. Drivers door switches all illuminate ok.
Regards to all, Johnnewzealand.
Panel switches illumination.
johnnewzealand
Re: Panel switches illumination.
Hello John,
Regret this is rather outside my experience. I think you have some detective work to do. Obviously check for basic plug type issues first. This type of multi issue problem can be somewhat frustration. One has to decide whether there is a cable, module or switch fault and then go from there. It is well worth considering second hand parts which will help keep costs down. Eurojag are a good source and advertise in our magazine.
We have several other regular experienced members posting here on this BB and it may well be that they will be able to provide better information than I can on these repairs. Phil/Brian/Doug, can you help on this please?
I had a similar experience of loss of all instrument lights on everything, at the time it was raining intermittently and I was trying to adjust the wiper delay rate............It took me a while (about a week) to realise that I was adjusting the dimmer for the instrument lights, how foolish did I feel having posted it on here.
Daft as it may seem can I suggest you look in your hand book to see where this control thumbwheel is (mine is an early half moon type dash so maybe different to yours).
Hope that is of some use
