Hello,
The mileage and trip computer display on my 96 Daimler Six has faded so badly that it cannot be read accurately. Can this be repaired, or will I have to source a new display unit from another car? If I do have to replace it, am I right in assuming it will have the mileage of the donor car? Thanks in advance.
Regards....Dave.
Faded Mileage Display.
Re: Faded Mileage Display.
Dave, it will be the bulbs at the rear of the display that have failed, easy fix if you know how!!
remove the dash pod, four screws accessed from underneath, well hidden but essentially one at each corner, once these are out, lower the column to it lowest point and extend the column to it furthest point, then ease the pod up and back, get your hand in behind and disconnect the two multi pin connectors, open up the pod from behind and replace the blown bulbs
reassembly is the reverse as they say!!
this may help a little
http://www.jaguarclassicparts.com/uk/ja ... -4-0-litre
I have bulbs here if needed
you are correct if you swap the whole pod, you will gain the mileage of the donor car
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
DaimlerDave.
Hello Rob,
Thanks for the reply. On the odd occasion when the display is a bit brighter (once every blue moon), the digits can look a bit broken up, if you know what I mean, hard to tell a 6 from an 8 etc, so I wondered if it was the same type of problem that can occur with the time clocks on these cars (including mine!). I will be very happy if it is cured by just replacing the bulbs. Everything else with the dash is spot on, just the mileage/trip comp display section. How many bulbs will I need if that is the problem?
One last point, if I need to change the unit, I'm guessing that I will only have to fit the display module from the donor pod as it appears to be a separate unit. Thanks again.
Regards...Dave.
Regards...Dave.
try the bulbs first, you need two from memory, tbh if you have to change the whole pod it is just as easy to do that rather than strip two down to get at the display module you need, I have pods here, all circa 110/120k miles
however if you have broken digits, bulbs will not cure that
DaimlerDave.
I'll try the bulbs first, got to be worth a try. I'll let you know how I get on. Thanks for your help and advice.
Regards...Dave.
Regards...Dave.
feel free to call or email if you get stuck, 07747 130 139 and 01890 761759, email contact is in the magazine
cheers rob jenner
cheers rob jenner
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
