My 1997 XJ8 4.0 V8 - 91,000 miles and new timing chains and tensioners at 67,000 miles - has a clicking noise at idling speed but stops when the engine speed is raised. The click also cannot be heard when driving. I use 5W 30 oil.
I've been told it could be a valve but this cannot be identified unless all valves are examined; it could be a valve lifter; timing chains; wrong oil; oil pressure. It has just been serviced and the engine was flushed but the noise is still there although it appears to be a little quieter.
It's not very clear whether this is a harmless and/or usual problem but I think it's necessary to investigate.
Any knowledge and advice on this please?
Engine knock when idling only
Re: Engine knock when idling only
Hi, others on here will undoubtedly be better able to advise, but if it is any reassurance I had similar on my XJ8 and the previous XJ40 (more so on the XJ8), and was told it was valve seats and not to worry about it, unless performance diminished or it started using oil. I just ignored it therefore and it remained the same. But I am no mechanical expert.....
XF Sportbrake 2020 / XK8 1998
sounds like the VVT to me,
located at the front of each cam cover , they can make a ticking noise when getting old
use a slightly thinner oil to get to the upper galleries quicker when cold , or at tick over,
you can also put an oil additive in , like molly-slip etc , will make the cat purrrrr again with little cost
yep, 4.0 "clack" sticky VVT, live with it!!
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
I have a VVT unit which ticks when the engine is cold.
Variable Valve Timing, of course!
