Hi everyone
Can anyone tell me the code or colour name of the grey trim around the windows of my 2000 reg. I saw this a while back but can not find it now.
Bill
paint codes
Re: paint codes
Hi Bill ,
It's called Dorchester Grey and the code is LDP/342 ,
if you can't find the base coat in a Jaguar paint use Rover Dorchester Grey , the codes the same LDP/342
, any problems in getting it you can always PM me
Hope this helps
Nik
Hope this helps
Nik
Re: paint codes
Thanks Nic
I will give it a go. The car looks quite good apart from the paint peeling on the front screen trim it should make an improvement
Bill
Bill
Re: paint codes
Hi Bill ,
The peeling and blistering is caused by the lack of etch primer on the alloy sections , rubbing down , careful masking , etch prime , base coat and clear lacquer should sort it , any problems give me a shout and I'll talk you through the process , here is a brief synopsis of the work I did to mine a while ago
Nasty blister
Mask and rub down
Etch prime followed by grey primer
Flat primer and base coat
Hi grade lacquer
De-mask and polish
Best wishes ,
Nik
Nasty blister
Mask and rub down
Hi grade lacquer
De-mask and polish
Best wishes ,
Nik
Re: paint codes
Re: paint codes
Why thank you young sirGood demo Nik. Mike.
All the best
Nik
Re: paint codes
Thanks Nic
Looks great. As long as I don't have to use a Yorkshire paper to mask with
Bill
Bill
Re: paint codes
Hi Bill ,Thanks Nic
Bill
I'm sure The Sun will do just as well
All the best
Nik
Re: paint codes
Just don't use page 3 as any imprints left behind could require much polishing.
Mike.
Re: paint codes
Very true Mike , you don't want the job to go T*ts upJust don't use page 3 as any imprints left behind could require much polishing.Mike.
All the best
Nik
Re: paint codes
Very sorry I seem to have started something here do not want to cause controversy I will carry on using the Sunday Sport
Regards Bill
Regards Bill
Re: paint codes
Passing over the above body bits........it's worth noting that when newspapers are printed they often have rows of very small holes punched in them near to the edge of the page, presumably to help the newsprint along the tracks.
If you happen to use a piece with said holes as masking you will not be very happy when you peel it away, I know from bitter experience!
TonyS
TonyS
XJS Bulletin Board Moderator
Re: paint codes
Very true Tony , newspaper isn't a replacement for proper masking paper , I now have a very large and wide roll of proper paint shop masking paper , the use of newspaper was pure laziness on my part , I've now moved the masking paper to an accessible part of my workshop
The newspaper now goes into the paper collection for recycling
All the best
Nik
All the best
Nik
