electronic ignition
eddy49
electronic ignition
Postby eddy49 » Wed Oct 10, 2012 1:09 pm
Has anyone any experience of the Powerspark electronic ignition systems.
I am thinking of fitting one of their new distributors to my 1969 240.
Any comments on other types of electronic ignition would also be welcome.
piman
Re: electronic ignition
Postby piman » Thu Oct 11, 2012 9:43 am
Hello Eddy,
my reservations about these distributors is that he refers to distributor type, e.g. 25D6, which is useless for a replacement. All Lucas distributors have a five number code (sometimes with an additional letter suffix), you need to match this for your particular engine. (This often vary even for the same engine over a production span as engines are modified) This code is the advance curve for that model distributor to suit a particular engine and is essential for good running.
My personal view is that electronic ignition is over hyped, but that is personal, many have fitted them with good results. What I do is have a worn distributor rebuilt and properly calibrated, more expensive but I have more confidence in that approach rather than a cheap import.
eddy49
Postby eddy49 » Thu Oct 11, 2012 1:50 pm
hi Alec and thanks for your comments. I do tend to agree with you but one of the reasons I was thinking of changing was that I had a set of fairly new points fail--they broke at the hinge--and the replacement set I had in the car---correct set-- fouled with the rotor arm when fitted. Also as you probably know the distributor on the mark 2 is very difficult to get at and work on when replacing the points. I was considering the complete Powerspark distributor because I felt that there might be fewer problems if I bought the whole thing complete rather that modifying my own distributor which may also be worn. My understanding is that if you give Powerspark details of your particular car then they set up the 25D6 appropriately. I have also thought about the 123 ignition distributor but that is obviously much more expensive and I have also been told that it is really for high performance use and also requires change of coil and leads etc. I have used the Acuspark system--modified the distributor--on an old boat and that worked fine for several years. So I am agonizing a bit and am grateful for all comments and experience.
Thanks again
Eddy
piman
Postby piman » Thu Oct 11, 2012 3:27 pm
Hello Eddy,
as long as that is done it should be fine. It is perhaps less well known that the vacuum capsule is also marked and again there are many variations. There is an American company that remanufactures these now to the correct specification.
Postby J44EAG » Thu Oct 11, 2012 8:05 pm
Guys,
I follow fuel and ignition issues with a strange passion.
Alec`s views, in my opinion are always bulletproof.
I`ve played with the 123 system on XK engines and have found them flexible and responsive to cam profile spec ie 265/275/285 overlap and needle and fuel mixture control. All those items are so variable and tweekable. The bottom line is though that it is an exacting science.
My mod experiments done with limited resources years ago were without a rolling road. We made tweeks by the seat of the pants with the car simply being thrashed up the road to see if advance and fuel mods had any effect. Nowadays quick precise curves are rather better and vastly more accurately calibrated using a rolling road. That wasn`t an option when I did my stuff back in the 1980`s with Triumph Vitesse and TR PI units on the building site where we built my fathers house!
The long and the short of this ramble is that I`ve had some slight experience with the 123 system on a 3.4 S-type and have obtained good results. You get what you pay for with fuel and ignition equipment. Burlen Fuel Systems were top guys when I was involved with such matters and the 123 did everything it said on the box. It doesn`t do it straight "out of the box". Some knowledge of fuel, air and ignition curves are needed to get things functioning acceptably. That takes a certain number of years experience, understanding and gut feel and dirty fingernail understanding to be available. Roll on Ken Jenkins. He is a King in this respect. Contact details in our magazine.
I recently advised the 123 system to a Portsmouth Region member with that classic S-type a couple of years ago and enjoyed a day with him playing with ignition curves, carb needles and an exhaust gas analyser. Back in the mud again for the second time in thirty years! For a road car we went for low down torque and that made the car feel responsive and lively around town and on motorways. We were not really interested in full thrash peak power but more concerned with usability, acceptable emissions and to an extent economy. We ended up with something rather better than we started with and the set up remains unchanged since we set the car up.
My golden rule taught to me at Aviation College is that too much advance on the ignition curve at a critical point, will blow a hot hole in something. In other words, detonation is destructive (badly described as "pinking") but a controlled combustion is sheer joy.
Just my take and comment which I hope is handy.
oldtimer
Postby oldtimer » Fri Oct 12, 2012 9:58 pm
Hi Eddy,
When I was involved with Mk 2's during the sixties I seem to recall distrbutor removal was the quickest option to replace points. One bolt secures the distributor clamp plate to the block, with this removed just lift the distributor out. Now everything can be examined and serviced accordingly, including new points.
Refitting, if I recall correctly is straight forward,there is an offset drive so that it will only engage in one position. Refit the single bolt, then check the timing with a strobe.
The option of electronic ignition did not exsist, apparantly there was a problem of point bounce but it never but it never gave me cause for concern.
Hope that is of some interest to you
Oldtimer
Martec
Postby Martec » Sat Oct 13, 2012 6:10 pm
My experience of Lucas 25D distributors is of replacing a tired 45D4 with a 25D4 in an old 'B' series engine with instant improvement in so called clutch judder (wear in the dizzy bearings allowed the timimg to change at will). Also in replacing the MkII's old DMBZ6... dizzy with a 25D6 but it had the weights springs set up to my engine and axle ratio and petronix electronic switching fitted.
Both cars were improved considerably and gave sterling service until they were both replaced by ECU controlled coil packs (I like to try new ideas).
The 25D4 is sometimes given a bad name because the spindle bushes have a smaller bearing surface and so can wear out sooner, but fitting an after market electronic switching unit to it masks a lot of the spindle bearing wear, but cannot overcome wear to the springs and weight that control the advance curve.
The aftermarket electronic switch in an existing dizzy is a cheap fix, the 123 'dizzy' apparently gives electronic maps and predictability in a dizzy shape. ECU and coil pack allows for ignition changes to allow for later engine modification but is probably a step too far unless you want switchable maps for changing over from petrol to LPG or similarly economy maps to performance.
I still have the old 25D distributors as spares and have no complains about them.
eddy49
Postby eddy49 » Mon Oct 15, 2012 2:24 pm
Hi and thank you all for your interesting comments. I have decided to go with the Powerspark new distributor and will update with my findings
regards
Eddy
