The Jaguar Hand book is confusing to say the least (or is it me?)
Can someone plse advise tyre pressures front & back for my 2001 X308 3.2 Sport
Tyres are: 225/55 16
Thanks, Billy
Tyre Pressures
Gary220262
Re: Tyre Pressures
Know what you mean but apparently it all depends on what 'type' of tyres you have fitted, whats on yours billy ?
GARY
2000 S TYPE 4.0 V8 (for upsetting the wife ! )
2005 Mercedes E270cdi Avantgarde (for commuting and towing caravan)
Re: Tyre Pressures
I usally run on 30LB front and back at all times.....i run Pirelli Esemetrico 235-50-17 never had any trouble comfortable ride too........
Re: Tyre Pressures
Billy,
I don't know if you have a later handbook to mine. I've copied the page from mine below which seems fairly self-explanatory:
Most Jaguars of that era have two pressure recommendations "Maximum Comfort" & "Normal". I always run mine at the higher levels ie 32psi Front / 34 psi Rear.
Re: Tyre Pressures
Thanks All
I will go with the advice given
