Wanted Left and Right headlight wiper arms...
grantedwish
Postby grantedwish » Tue Jul 31, 2012 5:07 am
Wanted Left and Right Headlight wiper arms for a 1988 XJS-C. 5.3..
Or supplier of this item used if poss. I am located in Canada, (Ontario)....
Re: Wanted Left and Right headlight wiper arms...
Postby ptjs1 » Tue Jul 31, 2012 10:30 am
grantedwish,
There are change points in the VINs in 1988 as regards the wiper arms and also the if the car is LHD or RHD. If you've got a 1988-built cabriolet then it must be before the change point as it must have been built before the end of Jan
If you give a little more info on your car, then other members may be able to help.
grantedwish
Postby grantedwish » Tue Jul 31, 2012 2:00 pm
Thank's Paul. I have two XJS-C's an 87 built in 86 and the 88 built in 87. Yes the windshield wipers are different but the headlight wipers are the same. Both left drive. Have located wiper arms new but I think a used pair must be out in some yard? Barratt have them and classics also. I am asking for used part dealer contacts also if anyone will share?
Postby ptjs1 » Tue Jul 31, 2012 6:33 pm
grantedwish,
Sorry! I didn't read your first post properly to see that you meant headlight wipers!
Try:
Graham Hallett at Grublogger on +44 7771 508614
Eurojag on + 44 1325 722777
Clarkes Jaguar on +44 1435 863800
