First thing was to strip the car internally and all the external fittings including all the glass to see what the shell was like, the arches had rust parts of the sills and rear bumper areas, the bottom of the front screen and in the corners of the rear one. The front wing was shot as I knew but to be fair the rest of the car was very good. I bought a 2nd hand front wing and sent the car off to be welded and sprayed the same colour as my Mark 2 a Range Rover metallic BRG.
I took the head off one bolt was sheared and sent it away to be restored and unleaded. I bought a new radiator and air con rad cleaned the engine bay sorted out some wiring issues and put a K&N filter on. I needed some new chrome bits new front/rear bumper quarters a new window motor electric aerial etc etc. I used Heritage eBay and Grublogger who was very helpful and knows his stuff.http://www.google.co.uk/url?sa=t&rct=j& ... d=0CCQQFjA...
Once painted the rebuild started which was a lot harder than stripping it down! I put all new rubbers in for the glass a new HRW as the original was kaput, I bought some different alloys with P6000 tyres. I bought a new head liner board that I had covered in the same green leather as the seats and a fair bit of other trim. I modified the rear side panels to take a bigger speaker by getting rid of the cubby holes and re trimmed them with the green leather. I bought a new ski slope with matching Speedo elm wood while I had the Speedo out I put in bigger bulbs and painted the rev counter/Speedo needles white as they had faded. I bought a Momo wheel with hub which I had the green leather covered instead of the original black. The door cards and full carpet set including the boot came from Aldridge trimming and the original cream leather on the seats under dash etc was re coloured. The front seatbelts were replaced with new ones and the sun visors got covered in the green leather.
After a lot of time and effort it was starting to look like a car again I had a Pioneer IPod head unit plus amp with a central locking alarm fitted and the air con re gassed. It finally went for its MOT which it failed having holes/rusty front sub frame rear shocks and the brakes losing pressure. So dropped the front sub frame which was beyond economical repair I bought a reconditioned one and a new sphere for the brakes which cured the air leak. While the sub frame was out I had new wheel bearings fitted m I have also put in a reverse sensor kit that works through the rear view mirror.
It drives great it is quicker than I expected very smooth and relaxing to drive cruising at *** is a doddle feeling like 80 and it makes a great sound on full throttle with the K&N fitted and the front part of the air box removed to allow more air to be sucked in. I have not done my figures so I don’t know how much I have spent altogether but I will not be that much out of pocket if I ever sell it in time I might even make a profit.
A few before and afters:
