subframe replacement
andypryce
Postby andypryce » Fri Jun 08, 2012 5:08 pm
Hi all,
Seems my "ebay bargain" was too good to be true! (will I ever learn). My local mechanic tells me the front subframe is corroded and probably wouldn't pass an MOT, so does anyone know how much a front subframe replacement would be (1996 X300)? I imagine quite expensive as I believe lots of work involved.... I don't really want to scrap her as she is in such good condition otherwise.
andyp
XF Sportbrake 2020 / XK8 1998
Bungle
Re: subframe replacement
Postby Bungle » Fri Jun 08, 2012 9:49 pm
I'm sure I've seen somewhere it's about £1k including labour. Does anyone else have any improvement on this!?
Jaguar Newbie (and driving newbie only passed my test in Oct 2010).
Jaguar XJ40 Sovereign 1994 4.0L
andypryce
Postby andypryce » Fri Jun 08, 2012 9:55 pm
Yes, that sounds about right, oh dear! I gather the problem is sourcing the subframe, I have emailed xjrestorations, so will report back....
andy
Billys
Postby Billys » Sat Jun 09, 2012 5:36 pm
I thought I had a costly job when I needed my engine oil sump cover replaced when I noticed after I bought the car that a bodge up job was previously carried out near the oil drain plug.
I used a local independent garage who managed to source me a second hand part & labour costs were lower as he was familiar with Jags & breaks them for spares.
It really is worth shopping around if you decide to get this work done
andypryce
Postby andypryce » Sat Jun 09, 2012 6:03 pm
I agree, definitely will, thanks
andypryce
Postby andypryce » Mon Jun 11, 2012 4:04 pm
Well, not so bad as I thought! Seems after closer inspection the subframe itself is not too bad, it's the points at which it is bolted to the floor that are a bit corroded. He has cleaned them up and treated them and is hopeful they will last a while longer, so good news there. The fuel line that runs through the rear wheel arch needs replacing, but that's relatively easy , so fingers crossed !
Bungle
Postby Bungle » Mon Jun 11, 2012 9:38 pm
Good news :)
I plan to get my new XJ40 purchase fully checked over soon too. Wish me luck :)
andypryce
Postby andypryce » Tue Jun 12, 2012 10:17 am
Indeed!
Guernsey
Postby Guernsey » Tue Jun 12, 2012 4:35 pm
Hi, I have recently fitted a new subframe to my '92 4.0L
I bought it brand new from JustJagsUK For £100, the subframe comes complete with the rear bushes, I see they still have some in stock
The cost then is that while it is out you really have to replace all the bushes V mounts, steering boots, anti roll bar rubbers - and give the subframe several coats of paint especially round the welded joints so water cant get in for a long time
I also replaced the engine mounts as these get very hard after many years work ( Jaguar issued a bulletin in this respect to stop vibration at tickover)
Regards Steve
Jaguar Sovereign XJ40 1992 4.0L Auto
dhdove
Postby dhdove » Tue Jun 12, 2012 5:03 pm
Brand New......£100.......BARGAIN, well done :D
TonyS
XJS Bulletin Board Moderator
andypryce
Postby andypryce » Tue Jun 12, 2012 5:26 pm
Yes that is good value, cheapest I could find was £150 from Eurojag, used. Did you do the work yourself Steve? I am wondering if you have any idea what I should pay, given all the other bits that you said may as well be done at same time? Does around £1000 sound about right ?
Guernsey
Postby Guernsey » Tue Jun 12, 2012 7:52 pm
Yes I did all the work myself, as for the cost involved it's very difficult to work out
There are two special tools involved one is something most garages would have to support the engine, the other is to compress the springs the genuine tool is very expensive I made a spring compressor to do the job in about an hour, they may make a tool or hire one, again that cost would be charged to you
So £1000 pounds sounds a lot but by the time they replace every thing that is worn when stripping the subframe and their hourly rate it could reach that number
I had my tracking set before I replaced the subframe they set the wheels correctly but the printout showed the other settings camber castor etc to be well out more out than worn bushes would cause, so when having the tracking set after new subframe and bushes the settings were nearly perfect, so I believe the subframes when they age and get rusty twist due to the numerous forces against them
Steve
andypryce
Postby andypryce » Tue Jun 12, 2012 9:10 pm
Thanks Steve, that is useful.
robv12
Postby robv12 » Sat Jun 16, 2012 3:16 pm
100 quid for a new subframe is a giveaway, these were over 1500 quid last Jaguar price, it's even cheaper than 2nd hand ones, I have some here at 150, so better look at my pricing!!
swap over is straight nuts and bolts, BUT it is a heavy bit of kit and as mentioned above you need spring compressors, engine support, and a the car high up in the air to get the old one out and the new one in, lying on your back doing it is not fun, well not at my age at least
these pics will give you some idea, albeit on a 40, but the principle is the same
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
andypryce
Postby andypryce » Sat Jun 16, 2012 7:43 pm
Thanks all.
I have picked car up again today, he tells me subframe itself is good, but it is points at which it bolts to floorpan that were concerning him, on closer inspection he said not as bad as first thought, so has cleaned it all up and coated it to prevent further corrosion. MOT due February, so he said he would have a look before that, fingers crossed.... Has also replaced the corroded fuel line (£120 for part), oil change, filter, sparkplugs, air filter, rear pads (discs good) and redone whole of underseal, all for £470, so pretty happy with that :D
andy
