Turrets
Damian.Gardner
Turrets
Postby Damian.Gardner » Wed Mar 08, 2006 6:05 pm
Hi there, I have been changing my front pipes on my V12 (Wot a nice job on the drivers side =/) and I have noticed that behind were the airfilters are there is a large patch of rust infront of where I think the front turrets are. It has only rusted through the inner wings but not into the metal behind it. Can anyone tell me the best way to fix these? Can I just cut out the rust and weld a plate over the inner wing? Or would that be an MOT fail? Also is it possible to fix without taking the engine out and is this a common fault?
Here is sum pics
http://www.damez.co.uk/pics/Jag/1.jpg
http://www.damez.co.uk/pics/Jag/2.jpg
Damian
Mark_B
Postby Mark_B » Mon Mar 20, 2006 12:09 am
Don't if still is now but the way MOT used to be is if you can press quite hard with a 1/2" bar onto the area with no chance of it going through, it would be a pass, that test would be done especially on where new underseal was applied, in case someone had 'repaired' it with cardboard! If it's just surface rust and structually sound you could flatten it down and apply thick underseal and it'll most likely last another year or two. Otherwise, if it has rotted right through, as it's 'within xx centimetres of a suspension point' the only thing you can do is cut it out an weld a new peice in.
XJ-S 3.6 230k miles +
Telsmoneypit
Postby Telsmoneypit » Sat Mar 25, 2006 10:54 pm
Damian, this is a common problem on all XJ-S's. The turrets are a double skin arrangement and for some reason it's always the skin on the engine side that rots. Unfortunately it won't be 'surface rust' as Mark has suggested. Looking at the pictures you have supplied, it appears that a large section of both turrets are totally shot and the top skin will have to be replaced.
I repaired both turrets on my car last summer and managed to do this with the engine in situ, I have a straight 6 engine which has quite a lot of room around it but yours is the V12 which has b*gger all! It may be possible for you to remove the manifolds to obtain space to work but you will still have restricted access with the engine in place. If you decide to have a crack at it anyway, here's some tips:
Get a dremel and LOTS of draper cutting discs. A normal angle grinder is much too big to work in such a confined space.
You only need to cut through the top skin, don't take the second layer of steel out as well.
Once you've cut the grot out, coat the open wound with Dinitrol rust killer. Once that has gone off, treat the area by brushing on Dinitrol wax or waxoyl before you weld in new metal (it may melt with the heat of the MIG but it'll probably leave some protection there)
Once you've removed the grot from the top skin, make a paper pattern of the area you have removed. Transfer that to sheet metal and you'll get a perfect fit over the 'hole'.
You'll have fun trying to weld the panel in, but try and keep the bead as small as possible. You may not have room to get a grinding disc in there afterwards.
Good luck and let us know how you get on.
Terry
XK8 Antigua blue (with issues)
2005 X-Type Sportbrake (Triggers broom)
2004 X-Type sportbrake, 1967 S type ..and my lost love..1990 XJ-S 3.6 coupe
