Electrical
sovereign500
I have an intermittent problem with the rear parking sensors. When reverse is engaged there is a continuous tone from the rear sensors even though there is nothing behind the car. The car has been returned to the dealer for warranty work, (a very reputable dealer) but he does not have a clue where to start looking. All connections appear fine. Any ideas?
Re: Electrical
I`ll jump in here if I may please.
My S-type has had this problem, not once but twice now.
The first time the module in the boot drowned through water ingress. 6" of it actually. Faulty boot seal caused the problem. The internals of the module box and the pc board died though corrosion and wet. You can open the box to inspect. The plug connection also does not like damp. You might clean and lightly grease with Vaseline to try for a fix. In the end with mine, a new module fixed the problem.
Now I have a long tone when reverse gear is selected with the now four year old module fitted. As usual my car has a boot full of tools and boating junk and I am going to have to heave it all out on the floor to investigate. I`d put my money on module failure again.
Via my Forum, I have seen this issue several times. One thing is certain. If you replace the module, you MUST fit the exact same one again. The part number is on the box and that is the one to replace with. Modules with differing numbers don`t seem to work.
Eurojag are good for second hand parts of this nature. I have found prices to be around one third or thereabouts for a second hand unit. Eurojag offer a short warranty with their units.
The sensor plugs accessible behind the bumpers are also prone to corrosion and often send the whole system into panic if not making good contact with their mating plugs. Clean and maintain as described above. I believe the bumper cover has to come off to get at the rear of the sensors.
Check all feed cables for breakages, corrosion or straining. The biggest problem with this kit is finding the fault. Once found, the solution often only costs a few farthings to remedy.
I think that gives a starting point. Can anyone else shed light on this matter?
Mike Kennedy
Mike Kennedy
Re: Electrical
Thanks Mike for your suggestions( even before I got to read the post!) That was good advice and I think the two systems would be very similar anyway. How did you get six inches of water in your boot....reversing into the sea?
Re: Electrical
If I can add a little to this. One of my sensors has the paint blistered and gives off a sometimes continuous and other times broken bleep, I have still to get round to re painting it, however it was explained to me that the ultrasonic jet (if that is the right term) is bouncing off the blown paint and causing the spurious bleeps.
Some other tips I picked up along the way...
Sometimes the gap in the Sensor rings get filled with dirt, if you can clean this with a soft brush it might help.
Each Sensor should emit a ticking sound when in reverse, go round each one listening for this, if one is not making the sound it could be that Sensor is at fault.
I have read that the two outer Sensors are accessible within the boot, by removing the rear light clusters.
Someone did have the problem solved by remaking a dirty wiring pin connection to the Module (Car loom side) he reckoned it was caused when water got into the Boot.
I read recently on another forum, about an S Type Owner who bought a new Sensor from E-Bay (£20.00) and swapped it with each Sensor, one at a time to, find which was faulty, luckily he started with the two outer Sensors and found it was the second one.
Hope some of this helps, let us know how you get on.
Doug.
Doug.
S Type Forum Moderator
sovereign500
Re: Electrical
Many thanks for the information. It at least give us somewhere to start.
Re: Electrical
Great info indeed.
I am seeing our Barry at Southern Day this weekend. I`ll take his rear light clusters out of his car or if required remove his bumper and nick a sensor to test out my car with.
I am sure Barry would oblige. Such a nice chap.
Re: Electrical
I had a similar problem about 2 years ago, it was fixed under warranty, it was a faulty sensor , the workshop couldn't replicate the fault but when I was able to show them they tested all the sensors and found one was on the blinkI have an intermittent problem with the rear parking sensors. When reverse is engaged there is a continuous tone from the rear sensors even though there is nothing behind the car. The car has been returned to the dealer for warranty work, (a very reputable dealer) but he does not have a clue where to start looking. All connections appear fine. Any ideas?
Re: Electrical
At Southern day, Ian Kelsey from XJK, Barry and I got together on this sensor issue.
Ian kindly came to look at my S-type which has a sensor issue as seen in the posts above.
We itemised which unit was not working. To do this, you have to place your ear right up against each sensor in turn. Those working emit a ticking noise.
Having found the defective sensor, Ian managed to get his hand up under the bumper cover and was able to move the cable connector. As if by magic, normal service was resumed. If you like me, have hands and arms like a gorilla, forget it. Long thin limbs are needed for the job. Otherwise it is a bumper off job.
We also found out that people have a tendency to over load paint on new units which then refuse to operate. The secret is to keep paint coats as thin as possible. It is also advisable to avoid getting paint between the outer escutcheon and the central sensor unit. Ian advised teasing insulating tape on edge into the slot between the two component parts to keep paint out of the gap between them. It can be a bit of a fiddle but use of a Stanley blade and with delicate positioning, this can be achieved. The tape is removed after painting.
So there we are. Hot breaking news from the Forums front.
Re: Electrical
Thanks Mike for the post and the success with the sensor inormation. Just out of interest which sensor was faulty?( On which part of the bumper?) I wonder if the access up the back of the bumper is uniform all along or whether hand slicing bits are in the way.
Re: Electrical
The rear structure on an S and a 350 are obviously likely to be different, but principles for sorting the problem would be the same.
My off side outer sensor was the culprit. Ian slid his hand up between the bumper cover and the rear exhaust box to give the plug connector a tweak. Not easy is you have meat hooks for hands!
The system now works perfectly again. I would sight corrosion as the problem. Ian just disturbed the connector slightly and an electrical contact was re established. Simple as that.
There are likely to be various obstructions behind the bumper such as exhaust boxes and structural sections. Only getting down and under will find just what is in the way for making access possible.
