ABS Warning
TimHills
ABS Warning
Postby TimHills » Tue Oct 07, 2008 8:53 pm
Hi All,
Our 3 Litre Estate has just developed a problem. About 10 minutes into every journey, the "ABS" Amber warning comes on, and at the same time the cruise control fails. As the only connection between ABS and cruise control seems to me to be wheel speed, I suspect a wheel sensor.
Am I barking up the right tree? And if so, where are the speed sensors, and most importantly, am I facing a big bill?
Can anyone advise?
Tim
BuckMR2
Postby BuckMR2 » Sun Oct 12, 2008 5:37 pm
Usually if its a wheel speed sensor the engine MIL will also illuminate as the engine management control unit wont be getting a speed input from one of the wheels.Can you get a code from the car?
BuckMR2,
'07 X350 LWB Sovereign TDVi,
MAPPED,2008Grille,Stainless Bumper Grille,Piped leather,REDSTUFF CERAMIC PADS,20"Calistos,2010Nav
Kitchen Sink etc
ng4xjs
Postby ng4xjs » Thu Mar 05, 2009 1:55 pm
Are you sure your cruise control has failed? The failure message is fairly high up the list of displays when something goes adrift.
Need to check first which wheel is causing the issue. You will likely need a digital fault code reader to do this. A common rear end fault is when the rear ABS ring parts company with the drive shaft resulting from corrosion caused by salt on the roads.
I had something similar recently on my wife’s car. Identified front n/s wheel as the culprit. Changed the sensor (£27.00) which turned out not to be. Changed the “Link lead” (£10. (cable from sensor to loom)) which (touch wood) seems to have done the job.
Hope you get it sorted quickly
Nick
ng4xjs
Postby ng4xjs » Fri Apr 17, 2009 1:19 pm
Until I have had a chance to have a look I’m assuming that a C1175 fault means my ABS ring has come adrift. I’m supposing it’s mechanical because I cannot re-set the ABS and MLF lights for more than about 100 metres. Any other thoughts warmly and greatly received.
This has not been a reliable car for me. In truth the least reliable Jaguar I have ever owned. I have lavished £1000s on a couple of XJSs over the last 15 years but ownership pride and the driving experience fully justified the outlay. The same, unfortunately cannot be said of the X Type, or at least mine.
That said, brilliant in the snow and a generally competent all-rounder.
BuckMR2
Postby BuckMR2 » Fri Apr 17, 2009 7:09 pm
The code is usually caused by your L/R wheel speed sensor ring.They corrode and fall off causing the MIL light to illuminate as it isnt getting a speed input from that sensor and the ABS to illuminate.Occasionally affected cars will stall when decelerating and/or have brake juddering through the pedal caused by the fault.
This problem was noticed by Jaguar starting in Scotland and then gradually working its way down the country (salt on roads, rain, causing the speed ring to corrode).
You will need an OUTER CV joint.These are not sided.Typical price is around £80 from your dealer.
YOU DO NOT HAVE TO BUY THE FULL HALFSHAFT as some dealers insist!
The job can be done in under 2 hrs.
My local Jag Specialist quoted £148 all in (ie parts,labour,VAT) to fix.
This was in a copy of the JEC book a while back (I wouldnt think it should be a problem to replicate on this site as its in the JEC clubs magazine?)
http://i71.photobucket.com/albums/i136/ ... of4001.jpg
http://i71.photobucket.com/albums/i136/ ... eP2of4.jpg
http://i71.photobucket.com/albums/i136/ ... eP3of4.jpg
http://i71.photobucket.com/albums/i136/ ... eP4of4.jpg
BuckMR2,
Kitchen Sink etc
ng4xjs
Re: ABS Warning
Postby ng4xjs » Tue Oct 21, 2014 5:47 pm
Had some issues back in 2009, different car and slight different problem. My ABS and handbrake light are both illuminated. I clear them with my code reader although no codes present themselves. The car will then drive okay for a few miles and the the lights will come back on.
I've checked fluid in the reservoir. I've checked the fuses (although I suspect the problem would be there continually if an issue). If it is an ABS ring or sensor then I would have expected the MFL to be on as well which it is not.
Any ideas please?
Nick
steve_m
Re: ABS Warning
Postby steve_m » Mon May 09, 2016 7:10 pm
My car just developed a squeak which turned out to be coming from the left rear wheel.
Investigation revealed that the ABS sensor was just touching the speed ring at one spot; apparently the carrier corrodes and expands slightly causing it to come into contact.
Put a couple of washers in and the squeak has gone away.
