hi everybody , im new to owning a jag , in fact ive only had mine for a week , anyway , i had in fact owned mine for roughly 14 hours when someone hit my rear bumper (not a good start) , ive manged to put it back on so the it dosent fall off , but are theere clips or mountings underneath that i may have missed , it dosent look like its sitting right on passenger side , many thanks in advance , rich
btw ive got a 1995 xj sport
rear bumper
you have two plastic mountings at the rear of the car a 19mm bolt goes through these and holds the bumper up, these are a pig to change, the bolt is often corroded into the mounting, you end up striping the bumper and destroying the mounting on removal, the rear bumper is also located on two plastic guides one at either side just rearward of the rear wheel arch, chances are you will have damaged one, some, or all of these mounts, you may be lucky, but not a cheap or easy fix if things are seized
