I have a 1961 Mk2 (3.4) which was restrored prior to me buying and I'm undertaking some detailing work. Can anyone assist with the location of the chassis plate or identification plate.In the book 'original jaguar,' I notice a plate on the buklhead between the battery and the heater. Is that where such a plate should be?
Many Thanks, Neil
Chassis Plate
I'm having similar difficulty to Neil. I wonder if these plates were fitted to different places dependent on specification?
The Jaguar service manual clearly shows it fitted to the offside inner wing level with the radiator top hose, about where the brake fluid reservoir is located. Nigel Thorley's 'Original Jaguar' shows it in this location on page 57, whilst it is under the starter solenoid on p 58/59 but not on the following page!
Paul Skilleter's 'Jaguar Mk2 Saloons Super Profile' shows the plate under the starter solenoid on p43 and 46, while it appears to be on the nearside inner wing on p53, approximately where the power steering reservoir would be located for cars fitted with PAS.
Again, in Nigel Thorley's 'Jaguar Mark 1&2' (Haynes) the plate is under the starter solenoid in the 340 model on p153 but not in the 240 on p146 or in the 3.8L on p81.
Best wishes, David (aka Confused of Timsbury)
On the S type the plate is between the battery and heater.
This is my 1965 3.8S engine bay
http://www.sweller.dynalias.org/images/3.8s-engine.jpg
Simon
Simon
neilcampbell
chassis plate
Thankyou all, as ever very helpful.
Regards, Neil
Regards, Neil
You could just look for the set of four holes left where the rivets were removed when the chassis plate was taken off. I'm doing a rebuild at the moment and I didn't have a chassis plate, but there's clearly four holes on the inner wing, exactly matching the chassis plate holes. So that's where I'm going to fix the new one.
Terry
Terry
