Finally fed-up with contact points, etc and upgrading to a 123 electronic ignition system. I'm renewing all ignition components at the same time, but not sure which coild to use. I've seen somewhere in relation to other cars that a "sport" coil isn't advised (with mention of "destroying" the ignition), but I've seen in other places people apparently using one happily. Any advice appreciated - I have to say that I'm not too clear on what the difference is between different coils is anyway!
Coil for 123 ignition?
Sports coils differ from standard coils by having fewer turns on the primary winding. This has the effect of increasing the step-up ratio, resulting in higher secondary (HT) voltage.
The downside is that the primary resistance is obviously reduced, which imposes greater strain on the primary switch, whether points or electronic ignition.
Most electronic ignition systems cannot tolerate a primary resistance lower than 1 ohm.
Since electronic systems are generally more efficient a standard coil should be quite OK. I know that 123 suggest a 'Blue' Bosch coil but then they all recommend a coil where they can make more money!
I have had a Lumenition system fitted to my 340, for over 14 years and a very good investment it was.
However the 123 system, which is much more recent, is a better bet.
