Removing Heater S-Type
sweller
Postby sweller » Sat Aug 08, 2009 8:33 pm
The heater flaps on my 1965 S type are stuck (in the hot position) - the small lever on the side of the heater is seized even with the control cable removed.
How is the heater attached to the bulkhead, how many screw/bolts? Anything to look out for?
I'm keen not damage the insulating material too much.
I'm slowly working through the niggling faults on this recently acquired car.
Thanks,
Simon
sweller
Postby sweller » Sun Dec 06, 2009 10:12 pm
I did this a month or so ago now - it was very easy.
Four screws and no need to damage the insulation. Once on the bench the flap freed up easily.
On examination I think I could have done it in situ. Plenty of penetrating fluid on the shaft ends, a brave heart and a pair of pliers on the 'free' end lever (the one that the cable isn't attached to) should have been enough.
Simon
ollyw750
Postby ollyw750 » Sun Feb 14, 2010 10:40 pm
I also did this a little while ago. When you remove the heater be careful to remove screw on the lower inboard corner of the heater unit, as it is not immediately obvious.
Oliver
