Centre Console- Removal
Moderators:robv12, DavidEm
geo912
Postby geo912 » Sat Dec 13, 2008 11:13 am
Can anyone advise how to successfully and simply remove the centre console. I intend to replace the auto gearshift module sometime, existing module functions o.k. but has split across J gate and whilst in there will attempt to replace bulbs or light fittings for both front and rear cigar lights, these failed after plugging in sat nav accy although the lighters both still function.
Will be glad of any advice.
Thanks.
geo912. 8)
liamxj
takes about an hour
Postby liamxj » Wed Dec 30, 2009 8:11 pm
hi
i had the same prob with mine got a new gear shift from e bay for about £35
to remove and replace is quite easy
first ease off shift surround carfully as this has small lugs holding it in this will expose bolts holding surround base remove these this will expose screws holding gear selector once these are removed you will have to unclip wood surround this is held in place with simple push clips.
next is the orkward bit gear shift is plugged in on pasenger side you will need quite small hands to unclip connector plug i think it slides forward then you can ease it out to unplug.
you might strugle to get wires back where they came out from but i tucked them down the side
then put back in opposite order
belive me it makes a big diferance to the look of interior i finished mine off with a nice new wood gear knob and a later model stitched gear surround good luck
ps i have also replaced a number of other cosmetic parts to my 1998 xj8
regards chris
Postby ptjs1 » Sun Jan 03, 2010 10:14 pm
I also need to remove the whole of the centre console to get to some of the main loom wiring behind the dashboard. Unfortunately my JTIS CD has got corrupted.
So, as per geo912's request, if someone could look up on JTIS how it is done, I'd be really grateful.
Tks
u102768
Postby u102768 » Mon Jan 04, 2010 10:32 am
Here you go:
Turn ignition switch to position II and apply footbrake.
Move gear selector to the the 'D' position. and release footbrake.
Turn ignition switch to position'O'
Remove battery cover and disconnect ground cable from battery terminal. Refer to 86.15.19.
Where fitted, remove centre console rear extension. Refer to 76.25.05.
Remove fascia centre veneer panel. Refer to 76.47.06.
Using a thin plastic lever, carefully release the rear air distribution control grill tangs at top and sides and remove grill complete with veneer panel and control.
Disconnect cigar lighter and ashtray illumination harness (white) multiplug at RH rear. of console.
Slacken and remove the two console rear securing screws.
Remove 'J' gate finisher and veneer panel. Refer to 76.25.24 and 76.25.26.
Slacken and remove the two centre console front securing screws.
Ensuring that harness is clear, pull console rearwards to withdraw front dowels from tunnel locations.
Remove console from vehicle.Remove console ashtray. Refer to 76.25.25.Remove glovebox and lid. Refer to 76.25.16 and 76.25.18.
Slide stud mounting plate off front of console.
liamxj
new part
Postby liamxj » Thu Jan 07, 2010 8:00 pm
hi
in case you havent got replacement part i just noticed the guy i got mine from on ebay still has some for under £60 for a compleat new module
item number is 120510883558
regards chris
