XKR wont crank
analyse
XKR wont crank
Postby analyse » Tue May 11, 2010 11:12 pm
Hi;
Im busy restoring my dream car, a (slightly) RTA-damaged XKR (1999) 4.0 convertible, and have got to the 'see if it starts' stage. When I turn the ignition, there's a whirring sound from the vicinity of the starter, but the engine doesnt crank. No doubt there are lots of electrical fun issues to come, but has anyone any suggestions before I drag it to my local expert ?
Many Thanks,
Howard.
Nik
Postby Nik » Wed May 12, 2010 9:11 pm
Hi Howard ,
Sounds like.............
1. Bad engine to chassis/body earth
2. Disharged battery/bad earth
3. Possibly inertia switch disengaged
Hope this is helpful,
Nik
analyse
Postby analyse » Wed May 12, 2010 11:52 pm
Many thanks Nik; I'll check these options.
H.
Postby Brakebuster » Thu May 13, 2010 5:02 pm
if you can hear the starter motor ' whizzing ' but the engine wont crank , then the starter solenoid is not working, it could be FUBAR or have a bad earth etc
the starter motor spins, and the solenoid throws this spinning motor onto the fly-wheel , and once the engine is started returns to a non spinning normal position
it can be the only thing ,
ensure you have a strong battery , and give the starter a ' tap ' on the side to try and free the solenoid, if this works, get it replaced as soon as possible, as it will never work right
