Cold Engine - tick/tack sound
smudge56
Postby smudge56 » Sun May 09, 2010 11:03 am
Hi all
Have 2005 XKR which has circa 50K on clock - have noticed a not so loud but distinctly audible ticking noise from left bank somewhere in the middle which fades as the engine heats up. Have been advised by family "expert" that this is most likely a dry valve that takes a while to get lubricated.
Any known cures? should I worry?
Vehicle is in for some minor cosmetics during the week and is still under warranty.
Experienced a similar noise when I had 2002 XK8 on 4.0ltr but never got anywhere with Jaguar who after 4 visits to workshop and assessment by Browns Lane engineer told me "they are all like that".
It is all a bit deja vu for my liking...
Steve :?:
Billroot
Postby Billroot » Sun May 09, 2010 5:14 pm
If it wasn't for the fact you have a XKR I'd suggest the variable valve timing units which are well kwown to sometimes make ticking noises from cold. However I don't think XKRs have them so it's not that. Next I would suspect the dreaded timing chain tensioners - have you had them changed? If not, it's a good idea to get the top ones done as failure usually equals engine rebuild.
Bill Root
smudge56
Postby smudge56 » Sun May 09, 2010 6:01 pm
Bill
Many thanks - as this is a 2005 model (built in late 2004) would it not have the latest most reliable tensioners already installed? Don't doubt your advice but thought Jaguar cured this issue in 2003/04?
Guess safest path is to talk to Jaguar dealer
Steve
Billroot
Postby Billroot » Mon May 10, 2010 10:03 am
Yes, I would have thought that your car has the latest type of tensioner. As it's still under warranty the dealer is the obvious port of call......My own experience of my local dealer is not good but I am sure they are not all bad. If you need a second opinion the best independent I have found is David Marks in Nottingham. He sorted a power steering problem for me in half an hour that had my dealer stumped. It was worth the long drive there to see him. Good luck.
Bill Root
Postby mike020150 » Mon May 10, 2010 10:44 am
Hi Steve,
Your car will have the latest tensioners so the noise isn't likely to be from them. Equally, your model of XKR didn't have the variable cam timing units fitted. Ticking noises can emanate from all sorts of sources including wear in the valve gear. However, your description of the noise's location and reduction/elimination when hot raises the possibility of a leaking exhaust gasket or cracked manifold. Examining the car on a ramp would make it easier to check out this possibility. Mike.
