Blower
Peter12
Blower
Postby Peter12 » Mon Apr 26, 2010 8:05 pm
I have a 1999 XK8 and when I stop, even after a short run the blower keeps on for a several minutes. The temperature gauge is fine and shows nothing unusual. I have had the water pump changed but with no effect. Its getting quite embarrassing. Has anyone else experienced this. Any ideas
Nik
Postby Nik » Mon Apr 26, 2010 9:21 pm
Hi Peter ,
Did you have the thermostat changed at the same time , if not get the stat changed ASAP as the early ones are known to be a bit of a problem :( ,
Hope this helps ,
Nik
PS Yes this happened to my 98 coupe a few years ago and a new stat cured it
Peter12
Postby Peter12 » Tue Apr 27, 2010 11:23 am
Hi Nik,
Thanks for the advice, I will change the stat and see if that will cure it.
Obliged
Peter12
