Engine stalls 1998 XK8 convertible
nick
Postby nick » Wed Dec 30, 2009 10:56 am
Engine stalled fault, 1998 Xk8 convertible has happened 4 times now over 2 months twice in reverse and twice in drive, cuts out, Still able to steer and brake starts back up as if nothing was wrong had a new gearbox 6 months ago, have been told its a common issue on these cars , would be grateful if anyone who has had the same problem could let me know how to sort it? Thanks Nick
designxkr50
Postby designxkr50 » Thu Dec 31, 2009 5:20 pm
Have you had your throttle body changed under the recall?
Kevin
1999 XKR convertible currently undergoing upgrade to 4.2l engine
nick
Postby nick » Fri Jan 01, 2010 11:37 pm
Hi there Kevin,only had this car 8 months not had the throttle body done myself, have looked through the paper work that came with the car, and there is no indication that a throttle body change has been undertaken, I had no idea they had been recalled is there anyway that I can check if it has been done? Thanks Nick
nick
Postby nick » Sun Jan 03, 2010 8:47 pm
Thanks for that Bleasie, will phone the local dealer with the vin no and service action number to check if it has been done.regards Nick
Postby mike020150 » Mon Jan 04, 2010 10:56 am
Throttle bodies on early cars were especially susceptible to stalling issues, making yours the prime suspect. However, it may be worthwhile paying for the services of a good Jaguar specialist or dealer to have an engine diagnostic check-up. An accurate diagnosis could save time in the long run as it's easy to chase phantom problems. Mike.
Postby J44EAG » Mon Jan 04, 2010 1:47 pm
Throttle body failure is a rare but known issue for XK8, X308 and both 3 and 4 litre S-types.
BBA re-man may be able to help you and avoid the need for buying new.
Here is the link for their site.http://www.google.co.uk/url?q=http://ww ... bEz3fqHJPw
Hope this helps.
Alternatively try e-bay for a good second hand unit. I recently bought a good one for £20 delivered! It was worth the risk and just for once I won!!
Mike Kennedy. S-type Co-ordinator
nick
Postby nick » Mon Jan 04, 2010 8:45 pm
Thanks for the replies, I have had an engine diagnostic done, unfortunately nothing came up and the advise was It could only be detected as it happened, however after stalling it starts back up as if nothing has been wrong, so its looking like a process of elimination, I am waiting for a call back from the dealer to see if the throttle body has been done on the recall, or if not what it would cost to have it sorted, will feedback as soon as I get the information. Regards Nick
Postby mike020150 » Fri Jan 08, 2010 12:42 pm
:?: Was the diagnostic check done on a Jaguar dealer's JDS unit or a specialist's Autologic system? Other brands of diagnostics are not always able to deliver the goods. Mike.
whitehead70
Postby whitehead70 » Sat Jan 09, 2010 2:20 pm
I had the same problem on motorways after about an hours driving. My throttle body had already been replaced.
I had the part load breather cleaned at the dealer and cleaned the throttle body myself using the instructions on the maxperformance website. This also has instructions for the part and full load breather.
http://www.maxperformancecars.com/dmdoc ... n_MAFS.pdf
The throttle body was fairly dirty.
The throttle body should be cleaned during the service but is apparently often overlooked.
Since then I have done two 5 hour trips with no reoccurence.
Neil
