Season's greetings to all !!!!!
The "DSC" switch in the centre console of my car has suddenly started failing to return to it's home position, ie push in and it seems to stick in that position. I have (very) gently managed to return to be inline with the rest of the console switches in the panel and the on/off operation of DSC seems fine, it's simply the issue of the switch returning.
Has anybody else experienced this and if do is there any easy cure ? How difficult is is to remove that switch panel and quite simply (famous last words !!!) replace the offending part if required ?
Kind regards,
Ray Brooks
Centre console switches
Hi Ray,
This is a bit of an odd issue for a switch which is probably the least used of any. The entire row of switches in the console is supplied as a single unit. Due to things like the optional heated seats, the switch packs vary slightly. Removing the unit involves removal of the centre console unit before access can be obtained. Mike.
