Sagging roof lining
johnxk8
Sagging roof lining
Postby johnxk8 » Fri May 08, 2009 12:15 am
I recently purchased a 2002 cabriolet and have noticed that the roof lining appears to be sagging, both at the front and the rear of the car. The dealership compared it with another 2002 car in for a service and it too showed signs of the same problem. Overall, it seems to be about 2cm lower than it should. Any suggestions on how to 'stick it back up' or do I just have to live with it? Any suggestions greatfully received.
pjnews
Sagging roof lining
Postby pjnews » Wed Nov 25, 2009 3:26 pm
Have similar problem with roof lining on a 96 coupe. Have tried re-glueing it but with little success - the board between the cloth lining and the roof needs to be replaced.
I'm being quoted £428 (for parts) by Jaguar - does anyone have any better ideas? Can the new board be introduced to the car through the door or does the screen have to come out?
Any tips or information would be appreciated.
Postby mike020150 » Sat Nov 28, 2009 5:01 pm
The seats have to come out first but the headliner can be removed without removing the screen. I would be tempted to ask one of the specialist Jaguar trimmers that advertise in the magazine if they could offer a better (cheaper) solution before ordering the parts. :idea: Mike.
pjnews
Postby pjnews » Sat Nov 28, 2009 5:10 pm
Thanks Mike - will take your advice.
It seems extraordinary that after 12 years the roof lining on a Jaguar is falling to bits while that on an equivalent age Ford or Vauxhall would probably still be as good as new!
Postby mike020150 » Sun Nov 29, 2009 2:55 pm
After penning my last note I came across a BB thread on the XJ Forum where a member has pics of the same problem repaired using a form of trim stud. Again, it might be worth considering if only as as a temporary repair. Mike.
designxkr50
Postby designxkr50 » Thu Dec 03, 2009 5:46 pm
What we have done on a couple of convertibles is to wet the roof lining and then heat it up (with a hairdryer or similar) as this often shrinks the lining back into place.
If this does not work then there are strings that thread through the roof between the lining and outer roof. They can be tightened up but they are not the easiest job.
S
1999 XKR convertible currently undergoing upgrade to 4.2l engine
