Driver Seat Electrics
Barrie05
Postby Barrie05 » Mon Aug 31, 2009 1:56 pm
The 10 amp fuse keeps blowing when the seat reaches 3/4 of its forward travel. unfortunately the travel is not far enough to allow acces to the rear fixings so I can remove the seat and check the wiring underneath.
Any idaes on how to get the seat out.
Or idaes on the fault.
Once I have started the car I can replace the fuse and the seat goes back fine all other actions are ok also.
Nik
Postby Nik » Tue Sep 01, 2009 10:11 pm
Hi Barrie ,
Don't suppose there is something under the seat obstructing the full travel of the seat or rails ? it's quite difficult to check but I'd have a good search with a torch :wink: ,
Hope this helps ,
Nik
Barrie05
Postby Barrie05 » Thu Sep 03, 2009 8:23 pm
Hi Nick
Thanks for comming back yes I did use a stong torch and sort of helped the wires extend but at that 3/4 travel it just blows the fuse.
I can't find any obstruction.
Thanks for your help
Regards Barrie
