Cruise Control: Engine Failsafe Mode
jagdaveh
Postby jagdaveh » Sun Mar 09, 2008 7:49 pm
Don't remember the last time I used cruise control but it worked fine. Tried it today and as I hit the set speed button, up comes an amber light and the Failsafe mode message. Obviously the cruise control didn't work!! Stopped the car and stopped and restarted the engine - the message had gone and the car drove fine. Next time I tried the cruise control the same thing happened. Any ideas on what the problem is and how to fix it? Otherwise it's off to have the codes read!!
Postby mike020150 » Mon Mar 10, 2008 6:26 pm
Hmm - I think you're right. It's a job for a code reader, preferably one operated by an experienced operator. Mike.
jagdaveh
Postby jagdaveh » Mon Mar 17, 2008 10:03 am
So it wasn't an electrical problem at all!! The fault codes indicated a low vacuum reading. A vacuum pipe had split going to the fuel pressure regulator which was affecting the cruise control system as well as leading to incorrect fuel pressure under normal running conditions. Took a while to track it down but at least the fix was easy.
Dave
Postby mike020150 » Mon Mar 17, 2008 5:58 pm
Yes, it is nice when the cure is easy and relatively painless on the wallet, isn't it? Glad it's fixed. The lesson for us all is, don't always blame the electrics! They may be complicated but sometimes the other bits do go wrong. Mike. :D
DoctorHoux
Postby DoctorHoux » Sun Dec 07, 2008 4:46 pm
I had exactly the same problem. In my case it was one of the solenoids that control the vacuum switch. These are located in the wheel arch I believe. It wasn't possible to identify exactly which solenoid needed changing, so all three had to be swapped out.
The excellent team at Hollygrove in Ringwood found this out with some determination and after much scratching of heads, which even involved a visit to a baffled Jaguar main dealer.
Well done to all at Hollygrove - they are a bunch of true Jaguar enthusiasts and experts who have looked after my XK for a fraction of the cost of a main dealer.
You can have the keys to my Jaguar...when you pry them from my cold dead fingers.
