XK8 servicing
After umming and erring about the possible consequences at resale time, I have carried out a standard service on my 4.2 litre. Without a hoist, the few jobs listed definitely take much longer than their direct equivalents on older Jaguars. Even a simple oil change is a pain because the sump plug is at the front; the filter only comes out from below and the car is too low to empty the sump with the rear end up on ramps. That said, nothing's impossible, just awkward (so what's new, it's a Jaguar!). The best thing about doing your own servicing is the opportunity to get to know your steed better. In particular, it gave me a good opportunity to examine the potential rust traps under the front footwells. What a design boo boo! If you haven't waxoyed yours after cleaning them thoroughly, don't delay too long. Prevention is better than cure.
just had my footwells repaired both sides..I knew about this prob but when inspecting the car before I bought it in July I checked the driver side..it seemed ok so didnt check the other not that it may have revealed anything because when I was getting the work done on passg side we checked driver side as well to find it had rotted thro as well..thats on a 99 with 75k
99 carnival red 18"flutes
