I've just had an LPG system fitted. It's brilliant, but now the heavy tank seems to be making the rear end sag a little (I'm also grounding out at the rear occasionally).
Are the any stronger rear springs I can have fitted to lift the rear end (an inch, maybe two) ?? Slightly firmer ride is OK, but I don't wanna go kart
KWE completely rebuilt the rear suspension last year (at HUGE expense !) - but they were very keen I kept the standard ride height, so I'm pretty sure it's on standard springs at the moment and that all is well with the shocks and springs etc.
btw - It's a 91 3.6 if that makes any difference.
Bigman
