Tried to start it a few days ago and it would fire from cranking (obviously from the cold start injectors) but as soon as she tried to kick in would die.
Got myself an adjustable power supply and tested the injectors with 2 volts, 8 out of the 12 were gummed up/jammed and wouldn't click when power was applied.
Upped the voltage to 4volts and with one wire attatched to a injector I just touched the other injector terminal with the other wire to make the circuit, just tapping it. There were a few small sparks each tap then the injector clicked and opened.
Continued round all 12, most stuck injectors moved with between 4 and 6volts but 1 needed a split second of 14volts to shift one stubborn one.
After doing all of them and all now clicking with 2volts applied I reconnected them all to the injector loom turned the key and off she went straight away and far smoother than I was expecting.
One happy XJS owner.
