Rear Seat removal - easy way to remove?
Moderators:robv12, DavidEm
bmc123
Postby bmc123 » Sun Feb 14, 2010 12:53 am
is there a method to removing the rear seat? I want to lift the seat up to check behind and under it and don't want to break anything :D
Postby Brakebuster » Sun Feb 14, 2010 11:26 am
the base is easy
remove the two heel-guards over the fusebox's, and then remove the two ( i think ) screws holding the base in place, then lift up at the front and remove carefully
however
to remove the rear seat back upright, you have to remove the seatbelt mounting points....not advised if you dont have the right tools , and your messing with safety devices
what do you want to look at, as there aint much back there, and you cant get to anything in the boot at all, its sealed
you do have to remove the full back seat to remove the rear shelf though
i have had all this out for several jobs, not too bad , but a little involved and you can easily damage the trim or leather
bmc123
Postby bmc123 » Sun Feb 14, 2010 3:54 pm
Thanks for that, I just need the main seat lifted out, not the back thankfully - its for cleaning purposes. 8)
DougX
Re: Rear Seat removal - easy way to remove?
Postby DougX » Tue Aug 30, 2022 7:02 am
I have a similar issue, I need to feed a wire through to the boot for a rear camera. I was hoping to find a hole through to the boot via removal of the rear seat. Took out the base but couldn’t get the back out. Didn’t remove seat belt bolts. However, from what is said here, there will be no point removing the seat upright if there is no access to the boot. Any suggestions how i can feed a wire through to the boot?
andypryce
Postby andypryce » Tue Aug 30, 2022 8:52 am
There will be wires attached to the right side ( I think) boot hinge, for the number plate lights etc, look for the grommet where they enter passenger compartment, should be able to feed wires through there.
XF Sportbrake 2020 / XK8 1998
DougX
Postby DougX » Wed Aug 31, 2022 6:43 am
Whete abouts does the wires come through? Behind the rear seat uproght? If so, will i need to remove the back rest to get to it?
andypryce
Postby andypryce » Wed Aug 31, 2022 4:27 pm
Yes, I guess that's true, so not a lot of help. Check in boot for any access to parcel shelf area?
Users browsing this forum: No registered users and 16 guests
