Help! No power XJR 2001 4.0 SC
Moderators:robv12, DavidEm
700SN
Re: Help! No power XJR 2001 4.0 SC
Postby 700SN » Tue Feb 16, 2021 12:29 pm
]:D I got a new working multimeter, (Hagotest HT118A) and tested as before..
(No key in ignition, no dash lights on.)
so with initial connection in series, registered -1.1 amps, dropping to around -0.93.
I then shut the boot, (using tiny crocodile clipped wire to pass under the closed boot). On first closing, it dropped right down to -0.260 amps, presumably as the boot lights went off.. Then left it about 5 mins and stayed constant. I couldn’t see any other interior lights on.
To ensure ECU completely goes to sleep I left it 20 mins..then went to -0.026 in “A” and -0.013 in “mA”
Not sure if that’s a “normal “ ish reading?
I’m not sure why it’s reading negative, the red “A” is connected to the neg battery terminal and the black to the loose earth strap...
Jaguar is unlocked.
Stu
Jaguar XJR 4.0SC 2001
Ford Sierra XR4x4 2.9i 1992
Ford Capri Cosworth 2.9i 1985
Andy P
Postby Andy P » Tue Feb 16, 2021 3:11 pm
Hi Stu,
Here is an interesting thread about battery drain on our beloved X308's.
Post No-10 has some very good information.
https://www.jaguarforums.com/forum/xj-x ... ns-206321/
Hope you get it sorted.
Andy :D
700SN
Postby 700SN » Tue Feb 16, 2021 5:23 pm
Cheers Andy, it seems ~30mA is ok from this posts, which it seemed was the last reading (26-33mA) between 20 mins and 1 hour.
Should I do the same test with the car locked up by the fob?
Stu
Stu
Postby ptjs1 » Tue Feb 16, 2021 8:20 pm
Stu,
Well done on the new purchase!
.026 Amps draw would normally be fine on an X308.
You seem to have one of 2 issues causing the symptoms:
- There is a strong parasitic draw that occurs when the car is locked, or
- Your battery, whilst able to maintain a reasonable voltage when unstressed, rapidly discharges when any current draw is demanded.
(I'm still surprised that it read as low as 3.8v after a while on the car? Most batteries are at 100% discharge at 10v)
So, I would do the following:
- Charge the battery (disconnected from the car) for a few hours so that it still reads c12.8v or above 30 mins after you've turned off and
the charger.
- Connect your multimeter on Amps setting. Keep meter outside of boot such that boot can be shut and readings still observed. Shut all doors and boot (don't lock car) let it settle for 30 mins to that expected ,026 A draw.
- Lock the car with the fob. Visually check that all door buttons have dropped and that boot is locked, and aerial retracted. Note Amps reading.
- Monitor reading over next 60 mins and note how it drops.
- Note steady reading at 60 mins in locked / alarmed state.
700SN
Postby 700SN » Tue Feb 16, 2021 9:06 pm
Evening Paul, thanks a lot!
So basically I’ll do the same thing but lock her with the fob - (with everything still hooked up to monitor for an hour. )
Is it right that the meter reads a minus reading?
Will do tomorrow & let you know.
Much appreciated
Stu
Stu
700SN
Postby 700SN » Wed Feb 17, 2021 7:48 pm
Hi Paul, all,
Successful with the below..!! Charged to 13.1v.
I came back after 2 hrs locked and reading was - 0.033-35.
Of course I then unwittingly opened the boot with the key, to unhook everything and the alarm started, so quickly de-activated it with fob. This naturally caused the ammeter to go a bit mad but went down to around 400 pretty quickly.
- I did however note that all doors were still locked!!
So I completely unhooked everything, put the earth strap back on the battery and unlocked fully with the fob.
Then I shut boot, and completely locked up by pressing the fob twice and she seemed to behave ok, with the second time “flash” of the indicators.
So it seems that it’s ok - however I will unlock and check voltage tomorrow...
Stu
Stu
700SN
Postby 700SN » Thu Feb 18, 2021 12:50 pm
Ok...I checked this morning - unlocked perfectly and the I checked the voltage, she was 12.73 with boot open and boot lights on.
So my conclusion is that I did not unlock/lock correctly (either in sequence or a mid-match of using key and fob ) to start with, plus having boot not fully closed when charging due to charge lead.
All this on a drained battery to start with.
Thrown into the mix was the rubbish multimeter I bought for £15 which did not register amps , which really wasn’t ideal...
I will keep an eye out, but really she needs to be driven properly!!
I really appreciate the assistance from Paul in particular and others and will update if needed!
Cheers!
Stu
Stu
Postby ptjs1 » Thu Feb 18, 2021 5:38 pm
Stu,
I'm pleased to hear that it seems to be behaving itself now! It's a pleasure to have been of some very small assistance to you. It's the real value of these forums. I've been the recipient of great help myself from other members at times of trouble!
Keep an eye on the battery. The 3.8v is still surprising, but if there was a small constant drain such as a boot light, I guess it could pull the battery past its expected zero capacity at about 10v.
I know its difficult in these strange times to get much use out of the car, otherwise I'd say just drive it a lot more! If convenient perhaps consider keep the battery always charged with an intelligent trickle charger. I have my Jaguars permanently on these at the moment.
keithc_1886
Postby keithc_1886 » Thu Feb 18, 2021 11:52 pm
Hi Stu, glad you've had an inexpensive positive result. Credit to your persistence in seeking an answer. If I've read your thread correctly the 3.8v reading was obtained with the same faulty multimeter that wouldn't record amps. If so I would be tempted to forget it.
An incomplete locking cycle that prevents the circuits going to sleep is a possibility that with any luck will not raise it's ugly head again.
well done and thanks for updating the thread, Keith
700SN
Postby 700SN » Fri Feb 26, 2021 8:45 pm
Just when you thought it was safe...
again thanks to Paul and Keith et el.
In light of the previous tests I bought a brand new 100A 950 cca yuasa 5000... top one IMHO.
I started her up, ran fine but engine amber warning light still on, so plugged in my cheap OBD reader, code 1606 came up.
That indicated ECM RELAY so bought another.
In the meantime I reinitiated the parasitic drain test and to my horror straight after shutting her off I noted a 3-4 amp pull which was way more than before. I disconnected her overnight.
The next day oddly enough after reconnecting and starting, the engine light disappeared but I replaced the relay anyway. (Incidentally the part no. Changed from LJA6703AA to T4N15704, I can recommend David Manners who are very helpful.)
Once she was running I had no warning lights , checked charging voltage = 14.2, was ok - (considering base was 13.3) - same on Rev to 2000 Rev on neutral. Tells me alternator is charging ok?
However after shutting down I then put the multimeter in series again, draws 4.9 amps !!
Reconnecting and start again, put multimeter in AC MODE and checked for AC across terminals.
Shows “0.000V” for a second, then “92.000V” and every second it flips, assume it’s because it’s AC?.
From that, I presume now I have a worn out or wearing out alternator /diode? Brush? which intermittently shows that it is failing, creating havoc with electrical circuits, relays, causing the AC reading which it should not have, right? This then leads to the diode leaving circuit open and then the ECM thinks to keep everything on, leaving a drain.
Being in failure mode, it may explain why sometimes it’s ok at 0.026 and other at 4.9A..
I’m probably now gonna order a new alternator, she needs a service anyway so I’ll get it fitted then.
If anyone can recommend a good supplier for the alternator that would be appreciated..I looked at jaguar and they take the **** at £879 and I’m sure they can be had for less than £200?
Unless I’ve missed something !! 😮
Stu
Postby ptjs1 » Fri Feb 26, 2021 10:32 pm
Stu,
It's true that an extremely high parasitic drain can be caused by a failed diode pack allowing current to drain. And your simple AC voltage check may imply that.
If you've got that very high amp drain, why not disconnect your alternator and see if it suddenly drops right down?
As regards a new alternator, I'd be minded just to get yours rebuilt. New rectifier packs aren't that expensive and there are loads of electrical services places around. I got the one in my XJS done last year. Much cheaper than a new alternator.
700SN
Postby 700SN » Sat Feb 27, 2021 4:31 am
Cheers Paul I’ll try and get underneath and see if I can unplug it..
Stu
700SN
Postby 700SN » Thu Apr 22, 2021 4:11 am
Decided to try a new alternator and have a massive 100,000 mile service incl auto box & sc.
Whilst testing everything out the garage saw smoke coming from the alarm siren so quickly unplugged it. the drain since, has been 0.02A to 0.03A and so looks ok. That makes sense that I may have fried it when I had the charger connected and inadvertently pressed fob with boot open.
Locked up overnight so I’ll see what happens!
Stu
700SN
Postby 700SN » Wed May 12, 2021 12:01 pm
Update- it seems like I must have mullered the security sounder when I pressed the fob whilst on charge.. it must have been an intermittent fault which eventually burnt out and shorted...once it was removed, no further issues.
I bought a spare from a scrap XJ8 4.0 to be fitted next MOT time.
That was a very expensive lesson ! 😮
Stu
700SN
Postby 700SN » Sun Mar 06, 2022 9:13 pm
BTW.. it’s fitted and no other issues. However she doesn’t blip when I press the fob a second time to alarm her. I’m a bit puzzled by that.
Ok, the security unit had been ripped out of a poor girl on the scrap yard but I didn’t suspect anything would have been wrong.
The scrapyard girl looked very well looked after and I was told unfortunately her floors, sills and bulkhead needed extensive welding.shame I couldn’t save her.
Is there anything I should check, I have heard some units can be set to silent- not sure why, or how.
Stu
