Hi Everyone. I have just joined the JEC as I am sure my membership will be in the best interests of my lovely 10 year old pristine silver XJ8 (reg 2000).
I will take some photo's and post them soon. I bought my XJ8 in March 2009 as a one owner car with just 66k miles and it drives like new. It had already had the chains and pretensioners replaced etc. Now has 74k miles and running great. Replaced the usual stuff on a preventative basis, water pump, new thermostat housing (aluminium aftermarket type from britishparts), also rear shocks, new aux belt, etc. Now planning gearbox service and diff oil change but dont know a Kent Specialist yet. If anyone can recommend a specialist anywhere that would be very helpful. Cheers. Mike
Hello - Just joined the JEC with my XJ8
Mike,
Welcome to the Bulletin Board. Whereabouts are you in Kent? I live in West Malling and have had good service from both Surrey Jag Centre (top of the Purley Way) and also West Kent Jags (Knockholt)
Mike,
I haven't got around to replying to your pm. Sorry.
Just wanted to say that you might consider trying to source the fluid yourself and then paying Surrey Jags for their labour. The big cost of the job is the fluid which has a retail cost of £23 per litre! However, you should be able to source it about £7 per litre if you hunt about on the internet. It's Esso LT71141
Reccomended Suppliers
the good news is there must be at least two of us who have used them!
Maybe its the old age problem creeping in
Re: Hello - Just joined the JEC with my XJ8
hi mike
i to have just bought a xj8 2002 70,000miles.dont they drive well.
i absolutely love this car. if you do happen to find someone who can change the oil in your gearbox would you let me know, as mine to needs replacing.
cheers troy
cheers troy
Troy,
Give Ray a ring at Surrey Jag Centre. Very close to you and more than capable of doing your gearbox fluid change. I have used Ray and his team on a number of occasions and have always found him thorough, fair and well-priced. Surrey Jag Centre are on 0208 689 3333 www.surreyjag.co.uk
