Cigarette Lid
Derek364
Cigarette Lid
Postby Derek364 » Tue May 15, 2007 1:03 pm
My cigarette lid has become loose. I've tried fiddling with it to try and snap it back into place with no luck. - might have to dismantle the centre console?
Any advice would be appreciated.
Sharfrs2
Postby Sharfrs2 » Wed May 16, 2007 12:17 pm
Does the whole ciggie lighter/ash tray unit not just pull out?
Remember those that gave their todays for your tomorrows.
Postby mike020150 » Wed May 16, 2007 3:45 pm
The ash tray should just pull out with a vertical pull. Mike.
GrandTourer
Postby GrandTourer » Wed May 16, 2007 8:54 pm
Derek, I too had the same problem when I had the car about 6 months.
I had the centre tunnel out anyway while I was fitting a Nokia phone kit in the armrest and was fiddling about with the ashtry mechanism for a while, but was not too successful. I did order warranty replacement from my local dealer, but while I was waiting for it I had to go to Scotland for a 3-day trip and just before I went, I had another fiddle around with the spring return mechanism and, hey presto - its been fine ever since.
I never did use the warranty replacement which the dealer sent back to Jaguar - I am sure they were happy :lol: :lol:
I think it sometimes is the tension in the assembly when fixings are tightened down or loosen up.
Karl, XK8 MY2000 Pacific Blue
Derek364
Postby Derek364 » Wed May 16, 2007 9:39 pm
Thanks guys. It is the spring operated lid that i am talking about, that (should) glide back into the armrest. It is a bit encouraging that fiddling with it may fix it, I'll have another attempt at the weekend.
Derek364
Postby Derek364 » Wed May 16, 2007 10:20 pm
I had a quick look at it tonight. I think the spring mechanism at the rear of the lid (connected to the armrest) should be attached to the lid in some way - it isn't. This looks like it could be a simple job if there was a diagram of how it should fit together.
GrandTourer
Postby GrandTourer » Thu May 17, 2007 3:40 pm
Derek, I know exactly what you are talking about because of my experience.
I would suggest you lift out the centre tunnel you get full access to the rear of the ashtray. It may be something as simple as a dislocated spring.
I don' know if you have ever had the centre tunnel out? It is a very simple way, but I understand if you a bit nervous if you had not done it before.
In the latter case, I would be happy to email you some instructions with photographs to help you along. Like with all of these issues, it is easy if you have done it once, but its the first time, when you worry of damaging something which is the nerve-bruiser :wink:
If you wnat me to email the details, just pm (personal message from this bulletin board) me your email address and I'll send you details within a couple of days.
Derek364
Postby Derek364 » Thu May 17, 2007 4:53 pm
Thanks Karl - have sent pm.
GrandTourer
Postby GrandTourer » Fri May 18, 2007 5:09 pm
Derek, have emailed you the info promised.
Good luck :)
Derek364
Postby Derek364 » Sun Jun 08, 2008 7:46 am
Karl, Finally built up the courage to dismantle the console yesterday. Mostly went ok, but it always seems that no matter how careful you are something will go wrong. One of the lugs broke off the selector surround as I was prising it off the wood - but a bit of super glue seems to have done the job and everything is back together now ok.
Thanks for the instructions you sent me - The ashtray lid plastic pivots had snapped off on both sides. So again repaired them using super glue. The lid now closes properly and is easy to open - but does not glide open - so 90% successful and a lot better than it was.
GrandTourer
Postby GrandTourer » Sun Jun 08, 2008 5:03 pm
Well done :wink:
