My cigarette lid has become loose. I've tried fiddling with it to try and snap it back into place with no luck. - might have to dismantle the centre console?
Any advice would be appreciated.
Cigarette Lid
GrandTourer
Derek, I too had the same problem when I had the car about 6 months.
I had the centre tunnel out anyway while I was fitting a Nokia phone kit in the armrest and was fiddling about with the ashtry mechanism for a while, but was not too successful. I did order warranty replacement from my local dealer, but while I was waiting for it I had to go to Scotland for a 3-day trip and just before I went, I had another fiddle around with the spring return mechanism and, hey presto - its been fine ever since.
I never did use the warranty replacement which the dealer sent back to Jaguar - I am sure they were happy
I think it sometimes is the tension in the assembly when fixings are tightened down or loosen up.
Karl, XK8 MY2000 Pacific Blue
GrandTourer
Derek, I know exactly what you are talking about because of my experience.
I would suggest you lift out the centre tunnel you get full access to the rear of the ashtray. It may be something as simple as a dislocated spring.
I don' know if you have ever had the centre tunnel out? It is a very simple way, but I understand if you a bit nervous if you had not done it before.
In the latter case, I would be happy to email you some instructions with photographs to help you along. Like with all of these issues, it is easy if you have done it once, but its the first time, when you worry of damaging something which is the nerve-bruiser
If you wnat me to email the details, just pm (personal message from this bulletin board) me your email address and I'll send you details within a couple of days.
GrandTourer
Karl, Finally built up the courage to dismantle the console yesterday. Mostly went ok, but it always seems that no matter how careful you are something will go wrong. One of the lugs broke off the selector surround as I was prising it off the wood - but a bit of super glue seems to have done the job and everything is back together now ok.
Thanks for the instructions you sent me - The ashtray lid plastic pivots had snapped off on both sides. So again repaired them using super glue. The lid now closes properly and is easy to open - but does not glide open - so 90% successful and a lot better than it was.
GrandTourer
