squeeling noise
i have a 2000 xkr ,69000 mls.first thing in the morning on start up the engine screeches (like a slipping fan belt ) 2 minutes later the noise stops ??????? any ideas or help would be welcome ...thanks
Re: squeeling noise
this is the classic sign if an old ' serpentine ' drive belt on the front of the engine
this time of year with the cold mornings etc the belt is stiffer than normal , this is also due to age , and the belt will slip and cause the automatic tensioner to knock and slip ,
a new belt will remedy the noise , also think about a new tensioner as well, about £25 for the belt , and ten mins to fit , and around £60 for the tensioner and about a further twenty mins to fit before the new belt goes on
easy DIY job
easy DIY job
Re: squeeling noise
AS BB suggests it sounds like the belt , new style belt requires the later tensioner
try British Parts for a bit of a deal ,
Hope this helps ,
Nik
Hope this helps ,
Nik
Re: squeeling noise
I`ve just done a belt change on my V8 S-type which is to all intents, virtually has the same power unit as an XK.
If you go to the S-type BB section, then "cooling" and look for "4 litre thermostat tower mod and fitting", you will find towards the later posts my description of the job together with photographs.
Hope that helps.
Hope that helps.
Re: squeeling noise
There is another reason that causes such noises - water (coolant) leaks
Look around the engine bay to see if there are signs of recent leakage
If this is the cause, sometimes it clears within about a month otherwise it's a new belt, tensioner & idle wheel (get latest versions to stop future problems)
Allan
Allan
XK8 Registrar
Re: squeeling noise
Hello
back in December 2012 I had a new ancillary belt fitted to my 1997 XK8 convertibe at 101Kmiles
During the winter the car has been used approx once per week and I get the sqeeling noise on start up this lasts for around a minute sometimes along with a slight knocking noise then the all the noises disappear.
I read the earlier post but they seem to relate to old belts not a newly fitted one
I have also had a warning on the dash at the same time saying "low oil pressure" which immediatley disappears as soon as the engine is revved. I noted this morning also a red light in the oil pressure guage and the guage moving from low to the middle.
Once the car is moving and starting to warm up the engine sounds very smooth with no noises (Tensions etc have all been recently changed)
Jaguar XF Owner
Re: squeeling noise
One cold winter many years ago
A twin cam engine with cam belt that also drove the water pump
Tried to start the engine, nothing moved, like siezed, then it turned over but no start
Examination revealed no anti freeze, frozen solid water pump, snapped cam belt, bent valves
IS YOUR ANTI FREEZE MIX SET CORRECTLY AT 50/50
Re: squealing noise
I'd suggest getting a specialist to examine the car. It will probably be necessary to leave it overnight to repeat the symptoms you have described. Without seeing the car naturally it's difficult to be sure but it does sound like you may have a failed VVT unit which is causing the oil pressure and noise issues. Mike.
Re: squeeling noise
can someone please explain how Nik is still posting
Para
Para
2002 Xkr 4.2 Adriatic blue reg Dez 7571
Gary220262
Re: squeeling noise
Hi Para, He isnt,what makes you ask ?
Gary
Gary
GARY
2000 S TYPE 4.0 V8 (for upsetting the wife ! )
2005 Mercedes E270cdi Avantgarde (for commuting and towing caravan)
Re: squeeling noise
Gary, look at the 3rd post in this thread, must admit I did a double take.
GeoffL
Happy owner of a 2000 XKR in Phoenix Red with full English Tan leather 63500 miles, Adaptive Cruise, Sat nav, Phone, Cold Climate/Memory Pack, 20" Chrome wheels, Premium Alpine Sound with 6CD changer.
Gary220262
Re: squeeling noise
Hi Geoff, suppose its easy to make a mistake if you dont notice date on post, god knows, ive been making mistakes all my life, !
Gary
Gary
GARY
Re: squeeling noise
You're definitely not alone there
GeoffL
