windscreen washers slow to start
andrew.graham97934
Postby andrew.graham97934 » Tue Mar 11, 2025 3:26 pm
Hi folks.
I have a 2005 built XKR coupe.
The windscreen washers, particularly on the driver's side take ages before any water emerges from the jets.
I tried blowing air through the jets recently, and I could hear the air blowing through but the screen wash is still pretty pathetic.
Does anyone have any suggestions?
Thank you.
Andrew
JimMann
Re: windscreen washers slow to start
Postby JimMann » Tue Mar 11, 2025 4:49 pm
Hi Andrew, I suggest you look inside the reservoir at the pump, which has a filter inline as this might be your problem - filter blocked or pump not operating fully / efficiently.
Jim Mann
Jim Mann
Banchory
andrew.graham97934
Postby andrew.graham97934 » Tue Mar 11, 2025 6:15 pm
Hi Jim. Thank you, and nice to hear from you!
That's a good idea and one that I should have thought of!
Many thanks..
Andrew
jagdaveh
Postby jagdaveh » Tue Mar 25, 2025 8:13 pm
Hi.
If the filter didn't cure your problem...
...when I had a similar problem it turned out to be very gloopy fluid at the bottom of the reservoir. It's a pain to get to behind the wheel arch liner but once it had been flushed out and filled with fresh washer fluid everything was fine.
CHeers
Dave
Thixendale
Postby Thixendale » Tue Mar 25, 2025 8:28 pm
This is all very useful advice as I have the same issue with my X350.
Thanks gentlemen.
Tony
MarkX
Postby MarkX » Sun Mar 30, 2025 9:44 am
One further thought, is it the screen wash used? Some years ago I found Halfords brand screen wash did not sit well with the washer pumps that BMW used - it seemed to foam up in the pump and eventually kill them. If you have changed your screen wash brand in recent times that may be a contributing factor.
Mark
