An article in the October issue of the magazine will no doubt be well met by many X100 owners.
Unfortunately, the author (Andrew Barrington) didn't provide an eBay link to the product and I haven't been able to trace it.
Hopefully, Andrew will pick up on this post and provide said link. Thanks Andrew in anticipation.
Ken Ward
X100 Window Waist Seals
2016 XJ 3.0 Ltr Portfolio
2000 XKR Silverstone
2010 XF Portfolio (Sold)
Re: X100 Window Waist Seals
It can be noted that JLR Classic claim to have XK8 waist seals in stock now for £106.25 including VAT, which is still significantly more expensive than the eBay option, but it is an OEM part. Link will take you to parts.
https://parts.jaguarlandroverclassic.co ... -seal.html
Jim
Jim
Jim Mann
Banchory
Banchory
Hi Ken,
This might be the item in question.
Jaguar XK8-R Door Window Trim Rubber Seal.
The seller is "rtay5993" and has good feedback on the item,here is the link:
https://www.ebay.co.uk/itm/Jaguar-XK8-R ... %7Ciid%3A1
Andrew Barrington must of purchased two which would be near the £40.00 he stated they cost.
Or this one,but it seems to cheap and not the right bit anyway:
https://www.ebay.co.uk/itm/Jaguar-XK8-F ... %7Ciid%3A1
Hope this helps a bit and good luck with your waist seals.
Take care.
Take care.
Hi, Andrew has confirmed that his eBay supplier is on the link below. He also notes that he will be at Castle Combe on Oct.20.20 and if anyone is there he will be happy to show off the fix and talk to others.
https://www.ebay.co.uk/itm/Jaguar-xk8-x ... 4423502573
Jim Mann
Jim Mann
Jim Mann
Banchory
Banchory
Thanks go to Jim, Andrew and A.J.P for the links. Hopefully, there may be a member or members that can benefit from Andrew's kind offer should they be at Castle Combe. In any event, the links will be useful to members in solving this common problem.
Ken
Ken
Note:It can be noted that JLR Classic claim to have XK8 waist seals in stock now for £106.25 including VAT, which is still significantly more expensive than the eBay option, but it is an OEM part. Link will take you to parts.
Jim
These are the inner waist seals, not outer.
