Wanted: bonnet lining/insulation for 1996 Celebration Convertible
DavidCosham
Postby DavidCosham » Sat Aug 04, 2018 6:04 pm
Has anyone got one of these in good condition for sale? I've tried all the usual suspects, and had no luck. Any advice would be much appreciated :) Thanks, David
David
New owner of 1996 XJS Celebration convertible
Looking forward to meeting and sharing interest in these wonderful cars
PaulGover
Re: Wanted: bonnet lining/insulation for 1996 Celebration Convertible
Postby PaulGover » Sun Aug 05, 2018 7:31 pm
I too would like a new liner, mine's for a '91 facelift; it's a black fibreglass mat shaped to fit. There seems to be nothing like it on the market. Kit car sundries supplies sell several self-adhesive foams that will probably do the job as well or better than the original. For example
Dodo Bonnet liner.
As they're almost always covered in aluminium foil, they'll look totally wrong. Many are "closed cell" foam, which I think is needed to prevent them saturating with petrol if there's a leak. ( I don't know if the original was proof against that!)
There are many American companies selling shaped "hood" liners made from what appears to be a dark grey felt. For example A liner for a Cutlass, whatever that is
Someone somewhere supplies rolls of the stuff, but I can't see anyone selling it, just car-specific fitted kits (and of course not for Jaguars).
Frost do a self-adhesive felt that doesn't look to good, but it might be possible to spray it with a suitable fireproof paint.
See here.
Some cheap high-temperature paint.
BigCatXJS
Postby BigCatXJS » Mon Aug 06, 2018 7:09 am
Mine has seen better days as well (pre-face lift). It has split at the points where it is attached to the bonnet along the top side (the end nearest the bulk head) and so is only held in place by two studs at the top side, the retaining disk, and those down either side of the bonnet. There is also damage where it rests above the fuel rails towards the front of the engine - almost if someone has deliberately hacked some of the insulation away to make space for something - most odd really.
If there is no real aftermarket option for bonnet linings for the XJS I wonder if these could be candidates for being added to the list of parts that Jaguar should consider re-introducing?
5.3 V12 (pre-facelift): BDC7973
3.6 (pre-facelift): BEC15591
I'm probably being a bit dim - but I cant see any bonnet linings for post-facelift cars under "Insulation/Liners" on the parts website - any pointers?
Ta, Rich
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
PaulGover
Postby PaulGover » Tue Aug 07, 2018 3:59 pm
Mine shows similar damage. I think what happened is vibration caused the lining to fret against the rubber seal on top of the radiator top mount, and then the cover splits and starts sagging into the area over the cooling fan. Then either threads get caught in the fan, or someone realizes the danger and hacks the drooping bits off to prevent a nasty whirling mat!
Tintin
Postby Tintin » Tue Aug 07, 2018 4:32 pm
I used automotive fabric adhesive to fix mine in position so that it no longer relies on the mickey mouse clips provided by Jaguar.
Robbie
Daimler Sovereign S1 4.2 1971
