Does anyone have one of these?
When doing the rear wheel bearings on my car I noticed this was cracked....
I have been ring around for 2 weeks with no success.
Quite a few of the breakers have them but will only sell me a whole axle assy. as a kit to upgrade to outboard brakes.
The cheapest (hah) option was then to get a new one from SNG. Delivered today and it wont fit.
Please help save a good car from the crusher.
CCC5701 Hub Carrier
Re: CCC5701 Hub Carrier
hi Iain
how ' bad ' is the crack , and where is it , got a pic? the web between the two cast legs can sometimes display a crack , however, this isn't fully stressed as modifications to racing Etypes etc mill out this section to save a little weight and give clearance
i have some brand new hub carriers sitting here, but they need the ABS sensor hole machined out, simples for a man of your talents i expect
when you say the others ' didn't fit ' , why was that
just seen that the very last hub carriers were the same as the X300/late XJ40 , is that like yours, or is it the more rounded earlier ones ?
VIN number will settle this question
Hi BB
VIN is 188579.
The crack means that the forward pivot bearing fell out when shook!
Yep wrong side. Also this is for a XJ40, they are not interchangeable, the pivot shaft is in the wrong position, just like the new one I have.
If I used a 40 one the wheel would have about 5 degrees of camber.
Thanks for looking..
VIN is 188579.
'93 4.0 Coupe, Flamenco red.
ah , i see
good luck with the hunting
