F Pace alarm beep
Moderators:jBlackwell, mike020150
stuart_bentley788
F Pace alarm beep
Postby stuart_bentley788 » Wed Aug 05, 2020 12:33 pm
Hi I own a 2017 F Pace Jaguar 3 litre diesel the car is running really well apart from one small niggle. When you have been driving for 10 mins or so the car emits a single 1 beep alarm. I can't see any reason for the alarm and wonder if any member can point me in the right direction, or if the car has a fault, the warranty on the car expires in September so I am keen to know if it is a fault.
Stuart Bentley
Re: F Pace alarm beep
Postby mike020150 » Thu Aug 06, 2020 10:09 am
As described, it sounds (pardon the pun) a little odd to me. These days, there are alarms for all sorts of things in modern cars. Have you checked the handbook to see if something you have done (like turning off the passenger airbag or some other safety system) isn't accompanied by a periodic warning beep? Otherwise, I'd suggest contacting your dealer. Mike.
stuart_bentley788
Postby stuart_bentley788 » Thu Aug 06, 2020 12:13 pm
Hi Mike, thanks for responding, I have checked the handbook and can't see anything re. this, I will check with the dealer, i was hoping to avoid that under the current circumstances.
Stuart
