Hello,
I am new to xjs's and I was hoping somebody could tell me how long to go between oil changes and what oil is best to use.
oil changes
I would very much like to meet other XJS drivers in the North Devon area
There's going to be many differing answers to this one, but I change oil and filter anually. Best place to buy the filters are at any of the JEC meetings during the year or Stonleigh, £5 seems to the the going rate which is far cheaper then a local motor factors. As for oil, I like a semi-synthetic which seems a good balance between quality and cost. I prefer Millers which do a semi synthetic 20/50 but is harder to find so usually end up using Comma 15/40. I personally prefer the heavier weight oils as the engine seems quieter and smoother.
Pop
Pop
Oil Changes
Floppy
I think it very much depends on your annual mileage.
If high milles, 12,000 plus, filter once a year and oil change twice a year ie every 6,000 miles
Otherwise oil and filter once a year.
Re Oil, I'd go for the recommended Jag Lube spec. for your car.
ie Why put expensive semi/fully synthentic oil in your car if Jaguar didn't advise it in the first place and you are going to drain it out within a short space of time/miles ?
If you change it on a regular basis you're better off than putting expensive oil in and changing it less regularly
DHDove
DHDove
oil changes
This will make some of you cringe! Last month I did an oil change but in tidying up the garage I noticed that over the years I had accumulated a number of part-empty oil containers.
So... in went:
2 litres 15/40 CommaXT
3.5 litres 20/50 Classic Sport
1 litre 10/40 Eurolite
1.75 litres 10/40 Havoline extra
So far all's ok!
Pop
So... in went:
So far all's ok!
Pop
