Hi, does any one have the same problem? My car makes a noise like its fitted with a supercharger, a squeal, (not the alternator belt), when I floor the throttle above 2000 rpm. I've been told that the cause is the corrugated air inlet pipe.
My engine is fuel injected so has a long air inlet.
Any one have the same, or now of a cure?
Vernon
Air intake noise
Moderator:jBlackwell
Vernon
Nostalgia Classic 120
Modern S type jag
Modern S type jag
Re: Air intake noise
Sorry Vernon,
I'm still on good old S.U.s and I quite like the induction noise. I will ask Charles if I see him at next Tuesdays BBQ and let you know. I think his engine is an AJ16.
Reg
Reg
Thanks,
the noise only occurs after about 3500rpm, throttle open fully,
it's not very loud but it does lessen the normal exhaust song.
I do use the full power that the engine has available.
With only a 3 gear auto box, it does exceed the speed limit in second gear by quite a lot (not that I do that on public roads) .
Vernon
Modern S type jag
Modern S type jag
Is the car fitted with an air filter(s)?
If not, then I would certainly expect induction roar.
Yes mike there is an air filler.
I have not checked it to see if it has collapsed or has a hole. I think that must be my next job, thinking about it, it might be the filter making the noise.
Don't know why I hadn't thought of it before.
The air filter is under the offside front wing, I think the wheel has to be removed to access it, when ever I think of looking at it I get the urge to drive it instead, which always wins.
I will investigate the filter, you have motivated me to action.
Vernon.
Vernon.
Vernon
Modern S type jag
Modern S type jag
Hello Vernon,
Sorry, I didn't go to the BBQ last night so was unable to get any answers for you ( we opened a nice bottle of red at home instead and watched the dark clouds overhead )
I hope you get an answer to your problem.
Reg
Reg
Thanks,
I'm suffering the after effects of a slipped disk,
so any mechanical work will have to wait.
But will investigate the air filter.
Vernon
Modern S type jag
Modern S type jag
