Waterless coolant
Moderator:jBlackwell
vernon
Waterless coolant
Postby vernon » Thu Jun 12, 2014 11:18 am
has anyone had any experience with waterless coolant ?
It sounds like the answer to Xk cooling system problems, my xk120 does suffer from heat soak when it's switched of.
I think this is a common problem with the 4.2xk engine.
It sound good but expensive. :D
Vernon
Nostalgia Classic 120
Modern S type jag
NATONEIL
Re: Waterless coolant
Postby NATONEIL » Thu Jun 12, 2014 1:22 pm
Sorry Vernon I have not used it. I loose so much coolant owing to a small leak in my radiator that it would be uneconomical
Neil
Suffolk SS100 Jaguar
vernon
Postby vernon » Thu Jun 12, 2014 2:19 pm
Yes I've had a small weep from my rad core, rad weld stops it and Evans who make waterless coolant said rad weld could be used.
Was hoping to get some feed back from someone who has used Evans waterless coolant before I tried it.
The 4.2 holds a lot of coolant, about 16ltrs, so quite expensive.
Vernon
Modern S type jag
NATONEIL
Postby NATONEIL » Thu Jun 12, 2014 2:34 pm
It might be best if you get the leak fixed first. It will keep your radiator up to pressure and you might find you do not need it
Neil
XjRestorations
Postby XjRestorations » Thu Jun 12, 2014 4:10 pm
We are agents for Evans - it is really a good product. We have used it on V12 engines with excellent results - and we have used it in race application with excellent results.
The engine will run ever so slightly hotter - but far more controlled. The temperature wont suddenly spike in hot traffic for example.
Due to the cost - I would recommend ensuring you have no leaks or suspect repairs in the cooling system. I would advise fitting a new cotton reinforced coolant hose set and checking the radiator prior to use.
Kind regards,
Keith
vernon
Postby vernon » Fri Jun 13, 2014 4:58 pm
Thanks Keith, I have replaced all the hoses with cotton reinforced. I don't have any leaks or overheating problems . But I have had over heat when switched off, that is why I am thinking of going waterless.
Can you supply Evans coolant? As I live in st Leonard's would save on posting.
Vernon
Vernon
Modern S type jag
XjRestorations
Postby XjRestorations » Sat Jun 14, 2014 11:10 am
Hi Vernon,
We certainly can supply for you. We have a new stock due on Tuesday. Give us a call next week to discuss if you wish (01323 644047)
Kind regards,
Keith
vernon
Postby vernon » Sat Jun 14, 2014 1:42 pm
Thanks Keith, will do when I know who many litres.
Vernon
Modern S type jag
vernon
Postby vernon » Mon Aug 18, 2014 3:02 pm
Hi Keith,
Looks like I have a small coolant leak from the back of the cylinder head ( exhaust side) .
Not sure if gasket or cracked head.
I think I may have to pay you a visit.
Will phone when free.
Vernon
Vernon
Modern S type jag
