Full beam only, Help!!
TomCotton
Postby TomCotton » Thu Jul 10, 2008 6:25 pm
I have a facelift 1993 XJS recently purchased. Lights position one, ignition on, dim dip....... fine. Position two, full beam only, NO dip facility on using the dip switch on left hand stalk. Headlamp flash works OK with lights off. Have I missed something or has anyone experienced this? Would appreciate ideas as the handbook is not comprehensive on light relays etc.
Postby ptjs1 » Thu Jul 10, 2008 10:45 pm
Tom,
Welcome to the Bulletin Board! I assume that you know that late XJSs work on a "Pull for On, Pull for Off" Dip to Main Beam, rather than the usual "Push forward for Main, Pull back for Dip" basis. In other words the left hand stalk only has one fixed position and you pull against spring pressure to turn Main Beam On or Off.
I only mention this beacuse it sometimes catches out new owners.
If this isn't the issue, then I guess you might have a problem in the headlamp relay, control module or the stalk switch.
Good Luck
Paul Sinnott
XJS Registrar
PS If you haven't done so, could you please enter your vehicle in the register whne you get a chance. Tks.
ng4xjs
Postby ng4xjs » Mon Jul 21, 2008 1:34 pm
Paul – Absolutely right. I have experienced this with the headlamp control module. They can suffer a bit from dry/corroded connections. Good idea to clean them up with an appropriate electrical spray. Worked for me.
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
ng4xjs
Nick
