Jaguar XJ-S - S.O.S - Can you help?
vipervisual
Postby vipervisual » Fri Jun 15, 2018 12:50 pm
Hello,
Another day another problem :( Love this car waited so long to buy one. Its had a full service everything checked out. Was shaky to start when purchased 6 months ago, started working properly after I cleaned the ECU connectors. However after having the suspension fixed just got it back and its cutting out and behaving very badly!
Please see the video I posted, link below. Unable to control the revs. Could it be a richness problem? Please help me.
Close to giving up and very sad.
https://www.youtube.com/watch?v=2pcOIv- ... e=youtu.be
Thanks again to all of you for your support and advice from the beginning.
steve_m
Re: Jaguar XJ-S - S.O.S - Can you help?
Postby steve_m » Fri Jun 15, 2018 1:09 pm
Don't give up!
I don't know anything about the 3.6 but others will chime in.
At least it is actually running which is a better basis for diagnosis than some that have appeared in these pages!
Postby davidr » Fri Jun 15, 2018 1:31 pm
As Steve says don't give up! Its probably something fairly simple.
Does the car drive normally but misbehaves at idle? If so I would suspect the idle control has an issue. There is a stepper motor in there that could have got stuck perhaps?
vipervisual
Postby vipervisual » Fri Jun 15, 2018 11:25 pm
Thank you for your support. Which is the stepper motor in the diagram? I am having the ECU tested.
poprivet
Postby poprivet » Sat Jun 16, 2018 8:32 am
Remind us what year your car is, it makes a difference.
Best to add it as a signature.
Postby davidr » Sat Jun 16, 2018 9:21 am
The stepper motor is item 17.
As Pop says, it does help a lot if you give us the exact year and model so we can give better suggestions.
vipervisual
Postby vipervisual » Sat Jun 16, 2018 6:52 pm
1985 3.6 xjs manual
poprivet
Postby poprivet » Sun Jun 17, 2018 8:18 am
Then it won't have the stepper motor setup, the early 3.6 was controlled in a similar fashion to the V12 engine.
I'm not familiar enough with the early ones to offer much help, sorry.
steve_m
Postby steve_m » Sun Jun 17, 2018 12:20 pm
Check that the throttle butterfly is clean; I understand that these can get gunged up and cause all sorts of problems.
Vacuum leaks will also cause problems.
Have a browse through this, it might help.
http://www.jagweb.com/aj6eng/richness.php
vipervisual
Postby vipervisual » Sun Jun 17, 2018 7:54 pm
I'm having the ECU tested. If that doesn't work to solve the problem is there anyone that is willing to assist me. I'm located in Leicester.
I don't know what else to do. Had it 6 months, struggling to keep trying. My mechanic is very helpful and has tried too.
Guidance needed from someone with experience.
:cry:
vipervisual
Postby vipervisual » Sun Jun 17, 2018 7:57 pm
Also no hot air coming through, not even blowing at all. Could this be linked? Was fine before.
