Wheel Wobble!
almcl
Re: Wheel Wobble!
Postby almcl » Sun Oct 04, 2009 9:33 am
Generally speaking you should not use tyres older than 3 years.
And your source for that amazing statement is what, Steve?
Certainly not the car or tyre manufacturers who are still arguing about a six year limit:
http://abcnews.go.com/Blotter/story?id=4822250
Nor RoSPA, who quote figures of six years in store or ten on the road:
http://www.rospa.com/roadsafety/advice/ ... /tyres.htm
The date of manufacture is stamped on the side wall.
No it isn't. There's a code, from which the date can be deduced, but it's not obvious and contains some ambiguities.
Al McL
MichaelSB
Wheel Wobble!
Postby MichaelSB » Sun Oct 04, 2009 10:00 am
I have been following this thread with interest as I have a minor vibration from the rear of my car at 70 + through the body.
I recently had David Marks fit 6 new shockers / new front springs / wishbone bushes / and the car now has 4 new P6000 tyres, David told me his tyre fitter thought 2 of my wheels had a slight buckle however I have had them rebalanced and apart from requiring a fair few weights the fitter balanced them ok.
So what do I look at now?
Michael
Current
Jaguar XK8 4.2S Convertible
Polaris Ranger
T6.1 VW Campervan
Wheel Wobble!
Postby Brakebuster » Sun Oct 04, 2009 10:03 am
driving slightly slower ??
BigCatXJS
Re: Wheel Wobble!
Postby BigCatXJS » Sun Oct 04, 2009 12:23 pm
LOL!!!
Michael - if you are encountering minor vibration then I suspect it probably is the wheel(s) being slightly out of tru/very minor buckle. Weights can only do so much. If I take the cat up to 130mph - 140mph, then I still notice minor vibration which I attribute to the wheels being slightly out of tru. This doesn't really bother me, as it is only abroad on das autobahn that I let the cat streach her legs (usually between Munich and Stuttgart) :D
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
FELIX456
Wheel Wobble!
Postby FELIX456 » Sun Oct 04, 2009 8:51 pm
I had wheel wobble and got front wheels balanced- to no avail, so I had the rear ones done too.... CURED.
Always try the cheapest option first, I say!
Oh, and apparently it takes only 30 miles of driving to round off a wheel that has flatted after being sat on for a couple of months. They reckon...
If you do go for non Pirelli, try and make sure the odd-bods you buy have a 'J' code for Jaguar. There's a really good website I found which explained all the guff on a tyre, and each 'fast' car manufacturor has a code to tie a tyre to their cars.
Also, double check your insurance policy, last year my old insurer sneaked in a caveat that if my car didn't have on manufacturer recommended tyres, my insurance was invalid! In VERY small print. Sneaky. They're not my insurer any more.
steveww
Re: Wheel Wobble!
Postby steveww » Sun Oct 04, 2009 9:13 pm
<br /><span class=mtag>
Ouch!
masterb
Wheel Wobble!
Postby masterb » Sun Oct 04, 2009 9:30 pm
After attending to the Baby, decorating,cooking and gardening to name but a few tasks.
I actually got a chance to play with the car 4 a bit.
So I slapped on another set of alloys on the front, which had preety new looking rubber courtesy of mr goodyear 6-7mm worth.
Went 2 the garage check the pressures and then hit the motor way, and hey prestro!!! :!: :!:
Exactly the same! :evil:
I am going to stick the other alloys from that set on the back tom if i get a chance but i am not holding out much hope of a result.
Glad some one put the deciphering info 4 the tyres, as i was about to put a post on tonight saying"theres no bloody date info on my tyres!"
Will also try getting the rear tyres balanced on the original set, i really cant see it being balancing or tyre related, espescially the back as the wobble is pretty severe over 75 -80 ish.
I would love an easy solution though.
Cheers to all who have posted. :cry:
Wheel Wobble!
Postby Brakebuster » Sun Oct 04, 2009 9:33 pm
radius arms ?
worth checking.....
BB :?
masterb
Wheel Wobble!
Postby masterb » Sun Oct 04, 2009 9:53 pm
I've got some radius arms on the car, for sure!
What do you mean my checking them, or more precisely, what am i checking for?
They look solid, so are you suggest the bushes perhaps?
Wheel Wobble!
Postby Brakebuster » Mon Oct 05, 2009 8:33 am
yes, movement in the bushes
the large end can tear away from the cup support to the cars body,
the radius arm keeps the geometry of the rear cage/axles in relation to the car , without the arms the rear axles will want to twist fore and aft ,
wear and or corrosion with the radius arms can affect the safety and handling of the car
use a pry bar to look for excessive movement of the bushes , most peeps think they look fine until they are physically checked properly...
hope this helps
BigCatXJS
Wheel Wobble!
Postby BigCatXJS » Mon Oct 05, 2009 3:11 pm
BB - that's a very good point re: Radius arms. Mine were rotted through, so I replaced both of them at the same time as I was having my Koni shocks fitted. My new radius arm's weren't power-coated to protect from rust, so I have them regularly waxoyled. They are very exposed, so they will rot fast unless protected.
Past:
1985 E28 BMW M535
