New member
happycat
New member
Postby happycat » Tue Jul 02, 2013 10:07 am
Hi to all just to joined the JEC club so I thought I'll introduce myself because I'm sure ill be asking all kinds of stupid questions in near future ! I have recently bought myself a 1992 convertible 4.0 I also drive a new XJL, I have owned other classics in the past but this is the car I always promised myself,everything seems ok with her exept the air con is not working I'm hoping it just needs recharging,if not air con is not essential with a rag top! Looking forward to meet up at some events. Cheers Cliff
1992 XJS convertible 4.0 signal red
2012 XJL Portfolio
BigCatXJS
Re: New member
Postby BigCatXJS » Tue Jul 02, 2013 2:15 pm
Welcome!
Please ask away!
Some answers to common issues are available in older threads on the Bulletin Board that are searchable.
Hopefully, we will be organising a forum event later this year.
Cheers, Rich
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Re: New member
Postby ptjs1 » Tue Jul 02, 2013 3:18 pm
Cliff,
Welcome to the XJS section of the JEC Bulletin Board and congrats on the purchase of your convertible.
Unfortunately, I suspect that it won't just be a re-gas on the aircon. Aircon systems only need re-gassing because the gas has escaped somewhere, usually through one of the seals in the system. A decent aircon engineer will evacuate the system and then fill with an inert, traceable gas to determine where the leak may be.
If you update your profile to include your location, then other members may be able to recommend aircon specialists in your area. Also please remember to update your membership record with the details of your car. This is really important for the club to understand what cars are owned by members.
Good luck with fixing the aircon!
Re: New member
Postby Brakebuster » Tue Jul 02, 2013 3:54 pm
welcome
first of all , enjoy your XJS ownership , and tackle the ' issues ' when you feel like it
you dont mention if the aircon is on the original R12 , or 134a , if R12 , then you can use a drop in gas RS24 , and you dont have to change anything like you do for converting to 134a , as mentioned, do a Vacuum test first, then a leak test if no vac is held ,
btw, its a rule here, you must post pics of your car, or else.....lol
BB :wink:
happycat
Re: New member
Postby happycat » Tue Jul 02, 2013 7:51 pm
welcome
BB :wink:
Hi I will post some pictures when I get a chance, prob at the weekend. :D
2012 XJL Portfolio
happycat
radio reset
Postby happycat » Wed Jul 03, 2013 3:34 pm
Hi wonder if someone can tell me what im doing wrong! the two front speakers were not working,so I removed the radio found that one wire had come out of connecting block but also the connecter at the back of radio had some slight corrosion,so I have clean and repaired and replaced radio,and when prompted entered code, great everything is working,but now every time I get back in car the radio is asking for code!! I enter code and it all works again,but switch off leave car come back radio is not working and eventually ask for code again, then it all works until I switch off and we're back to square one :( cheers Cliff
2012 XJL Portfolio
Re: New member
Postby ptjs1 » Wed Jul 03, 2013 3:41 pm
Cliff,
It sounds as if a permanent live feed on the wiring block is not connected properly. Start by checking and remaking all the connections properly in that wiring block.
happycat
Re: New member
Postby happycat » Wed Jul 03, 2013 3:57 pm
Cliff,
Hi Paul thanks for quick reply forgot to mention,there is a black wire behind the heating control facia that you have remove to get radio out that is not connected to any thing,any idea what this wire is for?
2012 XJL Portfolio
Re: New member
Postby ptjs1 » Wed Jul 03, 2013 4:16 pm
Cliff,
On a 92 car, check to see if you've got a White & Blue wire in the block. If so, it should go to Fuse 6 in the left-hand fuse panel with a 5a fuse. This is the circuit that controls the radio memory. Check the fuse and the block connection.
happycat
Re: New member
Postby happycat » Wed Jul 03, 2013 4:44 pm
Cliff,
I'll check later have to do some work now :( regards Cliff
2012 XJL Portfolio
BRIANH
Re: New member
Postby BRIANH » Wed Jul 03, 2013 6:19 pm
Hi there happy cat I hope you enjoy our little gathering and fire away with the questions. I am sure somebody can answer most of them.
From the Forum point of view please make sure your car's details are registered with us and then get cracking.
Brian Harris
1988 XJ-S 5.3 Litre Convertible, Signal Red
1996 XJS 4.0 Litre Celebration Coupe, Ice Blue
1967 420 4.2 Litre Saloon, Golden Sand
happycat
Re: New member
Postby happycat » Wed Jul 03, 2013 9:06 pm
Brian Harris
Hi Brian thanks for reply,I thought I had registered my details,am I missing something?
2012 XJL Portfolio
Re: New member
Postby ptjs1 » Wed Jul 03, 2013 9:22 pm
Cliff,
I've just checked your membership details. You've updated them correctly. Tks.
Just to let you know that your paint colour is Signal Red. I've amended that for you.
happycat
Re: New member
Postby happycat » Wed Jul 03, 2013 9:28 pm
Cliff,
ok thanks
2012 XJL Portfolio
Max
Hello!
Postby Max » Wed Jul 31, 2013 5:26 pm
Hi, new member here, from Dumfries, proud owner of a 4 litre coupe, auto, 123000 miles, bought about a month ago, and I'm loving it! She needs some work on certain things, but nothing too major, as far as I can tell. Brake discs and pads, head-liner, some bulbs, maybe a water pump, definitely a radiator recore, but that's about it. Stand by for questions!
