XJ DAB radio
Moderator:ct575
trickymicky
XJ DAB radio
Postby trickymicky » Tue May 16, 2017 10:28 am
Hi, my second post regarding my XJ.
When my DAB radio is on and I switch on the heated rear window the radio goes off! When the heater is switched off the radio comes back......weird to say the least.
Has anyone had this issue previously?
raysearles
Re: XJ DAB radio
Postby raysearles » Tue Jun 06, 2017 2:00 pm
Not heard of that before now - but as all the gibbons for the DAB radio is under the plastic cover in the middle of the upper rear window sounds like there is a fault or a short on one of the connections - under warranty still ? (is used ex Jag dealer?)
raysearles
Re: XJ DAB radio
Postby raysearles » Tue Jun 06, 2017 2:01 pm
trickymicky
Re: XJ DAB radio
Postby trickymicky » Thu Jun 08, 2017 2:19 pm
Thanks Ray, the car is booked in for a once over and thankfully under warranty. Technology is good but a pain when it goes wrong. I'll post the results if its fixed.
trickymicky
Re: XJ DAB radio
Postby trickymicky » Tue Jul 11, 2017 12:07 pm
Problem rectified, a replacement rear windscreen was fitted.
