Power Steering Pump Leak
Hi all, I have a leak coming from the high-pressure hose assembly. Can anyone tell me if I can take the whole unit off and repair it with a kit, please? I'm having no luck searching for a kit to service the pump itself
Kind regards, Sam.
1989 Daimler Double Six
2002 STR
2002 STR
Re: Power Steering Pump Leak
AFAIK it's usually a very fine crack in the flared end of the hoses, so tightening only makes things worse. Seal kits for overhauling the pump certainly used to exist - typically a bunch of O rings, and a couple of aluminium fillers that replace the ones at the bottom of the screwed junctions to provide the mating surface for the flare.
Having done it, I don't recommend overhauling the pump unless you know there's a problem - it's hard to get the pump unit back in the housing - it's about 6" across and sealed with a matching O ring, but it's easy to nip it if the bits are mis-aligned. Just drain all the oil and refill with clean. The pumps seem to be very dependable. If there are small leaks, you might get away with adding a tin of any of the standard power steering oil treatments, though they're aimed more at the seals in the rack than the pipe ends and pump.
Otherwise it's a case of new hoses, which are expensive and I found hard to replace - very limited clearance for spanners at the pinion end. Theoretically a crows-foot adapter is needed to get the torque setting right, but I found my ones slipped of the nut despite being from a reputable manufacturer.
