XJ6 Overdrive
selminer
XJ6 Overdrive
Postby selminer » Fri Oct 27, 2017 5:19 pm
Hi All
I am currently trying to dismantle an overdrive from an XJ6 but I am having a few problems with the oil pump.
I have removed the plug and retaining screw but I do not know how to remove the round part with the two flat sides to begin withdrawing the pump valve. Any past dismantlers would you please tell me the correct method of withdrawl.
I am also looking for an overdrive gear lever. I have bought a new switch for the top but that is all I have. Has anybody got one surplus to requirements.
Many thanks for reading my post.
Peter Callender
E type series 1 2+2
Derbyshire UK
Mgcjag
Re: XJ6 Overdrive
Postby Mgcjag » Fri Oct 27, 2017 5:28 pm
Hi Peter..try a google search on ....compact type A overdrive....there are some good service manuals out there and youtube videos... Steve
Steve.. 1969 S2 2+2 E type..Daimler Sovereign S1 1971
selminer
Re: XJ6 Overdrive
Postby selminer » Fri Oct 27, 2017 8:42 pm
Hi Steve
Thank you very much for your response. You are right there are some excellent write ups and videos but the models they show are either older or smaller ( HP) models than mine. The Standard Triumph manual is a very good read and helps understand how the overdrive works.
Again thank you Peter
PPV
Re: XJ6 Overdrive
Postby PPV » Sat Oct 28, 2017 1:01 pm
Please see my post on other query.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
