Hello Folks
Does anyone know what fault code P1571 means ref Electric Park Brake.
Dave
Electronic Park Brake P1571
Dave Hart
Re: Auto handbrake
This might be helpful.
https://www.google.com/url?sa=t&rct=j&q ... JjVfaXPQTm
More details can be found on the internet by typing "Jaguar P1571" or similar wording into your browser search engine. Loads of other info available for this and other fault codes. Remember that the code points towards the fault or defective unit. It does not always give a definitive answer as the fault may just be down to a corroded connector or duff wiring.
Let us know how you get on.
Re: Auto handbrake
Hello Mike
I typed in Jaguar P1571 and as you say I gots loads of sites, mainly in America. There seems to be a number of results for the P1571 code, eg, Limp Home, Cruise Control Failure, Park Brake Switch, and the one I thought, low voltage from Battery. Other possibilities were damaged wiring around the motor /chassis area, dirt making the caliper stick and corrosion on connectors. One thing I wondered was :- is Jaguar Programming different for American models. This, because on one of the sites, a procedure was given on how to set/recalibrate the Park Brake. The first thing was to restart engine then press the footbrake firmly 5 times, you get the word Calibrating in the message centre. I tried and it didn't work I got no further than that, no message.
I've changed my battery Bosch premium. Fault has happened again once, so I'm waiting to see.
Dave
Dave
Dave Hart
Re: Electronic Park Brake P1571
Dave,
If it is an X350, 'P' don't apply to the parking brake, according to my listing for X350 - they' all 'B's, 'C's and 'U's.
What car? Your signature shows an S type and an XF, neither of which are X350's!Does anyone know what fault code P1571 means ref Electric Park Brake.
Hello Paul
Yes my current cars are an S Type and an XF and for the record a very reliable BMW Mini Clubman Estate which recently replaced an even more reliable Mini Cooper D (110,000 miles and not a single fault) far outstripping the Jaguars. The Electronic Park Brake components are common to the X350 ,S-Type and XF, so the "programming" by Jaguar is as quirky as ever. My fault has gone since changing the battery, see the XF forum.
Dave
Dave
Dave Hart
